I am following the instructions on http://elinux.org/BeagleBoardUbuntu to get Ubntu installed on my BeagleBoard.
I have done the Flasher steps and also created the Ubuntu SD Image, but it does not boot up.
The following is the output:
U-Boot 2014.07-00014-gae1db02 (Jul 22 2014 - 10:58:18), Build: jenkins-github_Bootloader-Builder-371
OMAP3530-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 600 MHz
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Beagle Rev Ax/Bx
Timed out in wait_for_event: status=0000
Check if pads/pull-ups of bus 1 are properly configured
No EEPROM on expansion board
Die ID #311400020000000004013e8803024013
Net: usb_ether
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Checking for: /uEnv.txt …
Checking for: /boot/uEnv.txt …
44 bytes read in 30 ms (1000 Bytes/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-3.15.3-armv7-x4 …
4678776 bytes read in 4259 ms (1 MiB/s)
loading /boot/dtbs/3.15.3-armv7-x4/omap3-beagle.dtb …
60325 bytes read in 215 ms (273.4 KiB/s)
loading /boot/initrd.img-3.15.3-armv7-x4 …
3659108 bytes read in 3314 ms (1.1 MiB/s)
Kernel image @ 0x80300000 [ 0x000000 - 0x476478 ]
Flattened Device Tree blob at 815f0000
Booting using the fdt blob at 0x815f0000
Loading Ramdisk to 86baf000, end 86f2c564 … OK
Using Device Tree in place at 815f0000, end 81601ba4
Starting kernel …
[ 2.040924] edma-dma-engine edma-dma-engine.0: Can’t allocate PaRAM dummy slo
t
[ 3.038360] ehci-omap 48064800.ehci: Can’t get PHY device for port 1: -517
[ 3.137084] omap2_set_init_voltage: unable to find boot up OPP for vdd_mpu_iv
a
[ 3.144775] omap2_set_init_voltage: unable to set vdd_mpu_iva
[ 3.150909] omap2_set_init_voltage: unable to find boot up OPP for vdd_core
[ 3.158294] omap2_set_init_voltage: unable to set vdd_core
[ 3.184631] omap_i2c 48060000.i2c: timeout waiting on XUDF bit
[ 4.177520] omap_i2c 48060000.i2c: controller timed out
[ 4.226745] Error: Driver ‘tfp410’ is already registered, aborting…
[ 4.361785] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 4.369476] sr_init: platform driver register failed for SR
Scanning for Btrfs filesystems
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --debug option to see the details of our search for an access method.
[ 6.005981] mmcblk0: error -84 transferring data, sector 40960, nr 264, cmd response 0x900, card status 0xb00
[ 6.214813] mmcblk0: error -84 transferring data, sector 41224, nr 32, cmd response 0x900, card status 0xb00
The last two lines repeat until power is removed from the BeagleBoard, there is no stopping it.
Any thoughts, or guidance would be greatly appreciated.
