Apologies in advance for this very long e-mail.
As far as I can tell the set-up on the SD card completed all the way.
I have Ubuntu running within my MAC using Parallels so I had to use a USB SD card reader as the card would not mount on the internal SD drive.
The Beagleboard I’m running s the following…
http://www.liquidware.com/shop/show/BB-ULT/Ultimate+Beagle+Gadget+Pack
This boots up fine with the supplied SD card into the Angstrom OS. I have not attempted to connect the Beagleboard to any PC.
I turned the Beagleboard off, removed the Angstrom SD card form the SD card slot attached to the board , inserted the new Ubuntu SD card, powered up the Beagleboard and then nothing.
I then tried keeping the Angstrom SD card in it’s slot and booting with the Ubuntu SD card in the external SD hub. The Angstrom OS still booted up but the following error appeared on screen…
Mount Error
Cant Mount Device
org.freedesktop.Hal.Device.Volume.UnknownFileSystemType
Unknown File System 'ext4’
On a side note I have not been able to get the Beagleboard to display on my large LCD monitor, it seems when the device is booting there is a signal but when the system loads there is none, I don’t know if all these issues are related. I have been working off the small BeagleTouch screen.
The following is the output from the Terminal Window in Ubuntu when formatting the SD card.
A few warnings were thrown up, namely
WARNING: DOS-compatible mode is deprecated. It’s strongly recommended to
switch off the mode (command ‘c’) and change display units to
sectors (command ‘u’).
Command (m for help): Command action
e extended
p primary partition (1-4)
As advised I used the following ./setup…
./setup_sdcard.sh --mmc /dev/sdd --uboot beagle
Then I saw the following…
I see…
sudo sfdisk -l:
Disk /dev/sda: 8354 cylinders, 255 heads, 63 sectors/track
Disk /dev/sdd: 482 cylinders, 255 heads, 63 sectors/track
mount:
/dev/sda1 on / type ext4 (rw,errors=remount-ro)
/dev/sdd2 on /media/rootfs type ext4 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdd1 on /media/boot type vfat (rw,nosuid,nodev,uhelper=udisks,uid=1000,gid=1000,shortname=mixed,dmask=0077,utf8=1,flush)
Are you 100% sure, on selecting [/dev/sdd] (y/n)? y
Downloading X-loader and Uboot
2010-11-11 16:11:23 URL:http://rcn-ee.net/deb/tools/latest/bootloader [769/769] → “/home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/deploy/bootloader” [1]
2010-11-11 16:11:24 URL:http://rcn-ee.net/deb/tools/MLO/MLO-beagleboard-1.44+r16+gitr1c9276af4d6a5b7014a7630a1abeddf3b3177563-r16 [24296/24296] → “/home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/deploy/MLO-beagleboard-1.44+r16+gitr1c9276af4d6a5b7014a7630a1abeddf3b3177563-r16” [1]
2010-11-11 16:11:27 URL:http://rcn-ee.net/deb/tools/UBOOT/u-boot-beagleboard-2010.03+r65+gitrca6e1c136ddb720c3bb2cc043b99f7f06bc46c55-r65.bin [209712/209712] → “/home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/deploy/u-boot-beagleboard-2010.03+r65+gitrca6e1c136ddb720c3bb2cc043b99f7f06bc46c55-r65.bin” [1]
Unmountting Partitions
e extended
Partition number (1-4): First cylinder (1-482, default 1): Last cylinder, +cylinders or +size{K,M,G} (1-482, default 482):
Command (m for help): Partition number (1-4):
Command (m for help): Selected partition 1
Hex code (type L to list codes): Changed system type of partition 1 to e (W95 FAT16 (LBA))
Disk /dev/sdd: 3965 MB, 3965190144 bytes
255 heads, 63 sectors/track, 482 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x0000f106
Device Boot Start End Blocks Id System
/dev/sdd1 * 1 9 72261 e W95 FAT16 (LBA)
Command (m for help): The partition table has been altered!
Calling ioctl() to re-read partition table.
WARNING: If you have created or modified any DOS 6.x
partitions, please see the fdisk manual page for additional
information.
Syncing disks.
Formatting Boot Partition
/home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/deploy/MLO-beagleboard-1.44+r16+gitr1c9276af4d6a5b7014a7630a1abeddf3b3177563-r16' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/MLO’
/home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/deploy/u-boot-beagleboard-2010.03+r65+gitrca6e1c136ddb720c3bb2cc043b99f7f06bc46c55-r65.bin' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/u-boot.bin’
done
e extended
Partition number (1-4): First cylinder (10-482, default 10): Using default value 10
Last cylinder, +cylinders or +size{K,M,G} (10-482, default 482): Using default value 482
/dev/sdd2 10 482 3799372+ 83 Linux
Syncing disks.
Formating ext4 Partition
Populating Boot Partition
uImage
Image Name: 2.6.35.7-l6
Created: Thu Nov 11 16:12:09 2010
Data Size: 4430864 Bytes = 4327.02 kB = 4.23 MB
Load Address: 0x80008000
Entry Point: 0x80008000
uInitrd
Image Name: initramfs
Created: Thu Nov 11 16:12:11 2010
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 3942494 Bytes = 3850.09 kB = 3.76 MB
Load Address: 0x00000000
Entry Point: 0x00000000
Image Name: Boot Script
Created: Thu Nov 11 16:12:12 2010
Image Type: ARM Linux Script (uncompressed)
Data Size: 501 Bytes = 0.49 kB = 0.00 MB
Contents:
Image 0: 493 Bytes = 0 kB = 0 MB
Image Name: Reset Nand
Created: Thu Nov 11 16:12:13 2010
Data Size: 559 Bytes = 0.55 kB = 0.00 MB
Contents:
Image 0: 551 Bytes = 0 kB = 0 MB
/home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/boot.scr' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/boot.ini’
/tmp/readme.txt' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/readme.txt’
/tmp/rebuild_uinitrd.sh' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/rebuild_uinitrd.sh’
/tmp/boot_scripts.sh' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/boot_scripts.sh’
/tmp/fix_zippy2.sh' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/fix_zippy2.sh’
/tmp/latest_kernel.sh' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/latest_kernel.sh’
/tmp/minimal_xfce.sh' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/minimal_xfce.sh’
/tmp/get_chrome.sh' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/get_chrome.sh’
/tmp/gst-dsp.sh' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/dsp/gst-dsp.sh’
/tmp/gst-omapfb.sh' -> /home/skryne/Beagleboard/ubuntu-10.10-r1-minimal-armel/disk/tools/dsp/gst-omapfb.sh’
Populating rootfs Partition
Be patient, this may take a few minutes
355MB 0:01:45 [3.37MB/s] [=================================>] 100%
skryne@skryne-laptop:~/Beagleboard/ubuntu-10.10-r1-minimal-armel$
