Hi all, sometimes I have a problem with the SD card in my beagleboard
(angstrom os).
The problem happen when I reboot the board. I get this error:
[ 25.010009] EXT3-fs (mmcblk0p2): warning: ext3_clear_journal_err:
Filesystem error recorded from previous mount: IO
failure
[ 25.021331] EXT3-fs (mmcblk0p2): warning: ext3_clear_journal_err:
Marking fs in need of filesystem
check.
[ 25.031036] kjournald starting. Commit interval 5
seconds
[ 25.046844] EXT3-fs (mmcblk0p2): warning: mounting fs with errors,
running e2fsck is
recommended
[ 25.059478] EXT3-fs (mmcblk0p2): using internal
journal
[ 25.064758] EXT3-fs (mmcblk0p2): recovery
complete
[ 25.079833] EXT3-fs (mmcblk0p2): mounted filesystem with writeback
data
mode
[ 25.087066] VFS: Mounted root (ext3 filesystem) on device
179:2.
[ 25.097045] devtmpfs:
mounted
[ 25.100189] Freeing init memory:
208K
INIT: version 2.86
booting
Please wait:
booting...
Starting
udev
[ 26.175567] udev: starting version
151
Remounting root file
system...
[ 31.671875] mmcblk0: error -110 transferring data, sector 1872003,
nr 8, card status
0x0
[ 31.680816] end_request: I/O error, dev mmcblk0, sector
1872003
[ 31.686798] Buffer I/O error on device mmcblk0p2, logical block
131586
[ 31.693359] lost page write due to I/O error on
mmcblk0p2
[ 31.699188] Aborting journal on device
mmcblk0p2.
[ 31.714172] journal commit I/O
error
[ 31.765136] EXT3-fs (mmcblk0p2): error: ext3_journal_start_sb:
Detected aborted
journal
[ 31.783477] EXT3-fs (mmcblk0p2): error: remounting filesystem read-
only
Caching udev
devnodes
Populating dev cachetar: can't open '/etc/dev.tar': Read-only file
system
mv: overwrite '/etc/udev/
saved.uname'?
saved.cmdline'?
saved.atags'? ...
Is it possible that the problem depend on the SD card? I'm using a low
cost 2GB SD card (Apacer).
What kind of SD card do you use?
