Hai,
I am new to beagleboard,i try to connect my serial port in windows to see hyperterminal…but i didnt see any thing in terminal window…i dont know whats the problem…can anyone tell me what to do?what will the problem?
I selected
Bits per second :115200
Data bits :8
Parity :none
stop bits : 1
Flow control :none
After giving all this details i selected “apply” and “ok”…but i didnt get anything on my terminal window…help me
See http://elinux.org/BeagleBoardFAQ#Serial_connection_.231. Do you get characters with pins 2 and 3 tied together on your cable? Do you see the “40T” or “40V” when you apply power?
i dont understand what you are coming to say is…because i am newbie…
what is meant by getting characters with pins 2 and 3 tied together on your cable?
i just connected my serial port to beagleboard which have 10 pins indicated as RS232 with thw connector…
what is meant by “40T” or “40V”?
i got 4 LED is on when connected to power supply…That is PWR,USR0,USR1,PMU STAT(near RS232 pin)
Still not getting anything when i connect to hyper terminal…
Main thing is i didnt have my MMC card…Just i connected the serial port connection and checking whether the board is working properly…but i didnt get anything in my hyper terminal window…help me
I also faced a similar problem in the begining, and its because there are 2
types of RS-232 headers available in the market, and they differ wrt the
pinout as shown.
Type 1 : 10 9 8 7 6
1 2 3 4 5
Type 2 : 2 4 6 8 10
1 3 5 7 9
The Beagle Board requires the Latter one (2). The one I purchased turned out
to be the other one (type 1), so it didn't work.
I just made my own RS-232 Header according to the Pin config described in
the SRM and it works well. Only pins 2 (TX), 3 (RX) & 5 (GND) are required
so its very simple.
You can check the Pin configuration of your available RS-232 Header with a
Multimeter and confirm if its according to the BeagleBoard Pinout. If you
find
the Pinout is OK, try using a reverser as well with your NULL Modem
Cable. Your NULL Modem Cable might be faulty.
-Nitin
Read section 13 of the Systems Reference Manual. http://beagleboard.org/static/BBSRM_latest.pdf
It takes you step by step to make sure you have all of the correct cables for the serial port. Pins 2 and 3 are the transmit and receive pins of a serial cable.
