[beagleboard] Uboot for beagleboard (B7)
I am new to beagleboard. I have a beagleboard (Rev B7). I am trying to
boot Android on this board.
I have followed following instructions in order to achieve this
1. Partitioned the SD card using HP card formatting tool.
2. Copied following files MLO, u-boot, uImage from
http://code.google.com/p/beagleboard/wiki/BeagleboardRevC3Validation
----> to SD cards FAT32 partition.
3. Connected serial cable IDC10 to DB9 to beagleboard and the PC
4. Connected HDMI to DVI cable to beagleboard and the monitor.
5. Powered up the board using USB cable (pressed the user button
during power up)
Besides this I have followed all instructions from above mentioned
link and installed the required drivers (Linux.inf - When I was
prompted with New Hardware Detected dialog).
I even tried booting from the u-boot in flash (i.e. not with SD card,
and without pressing the user button).
However, I am unable to see any output on the hyperterm.Though the
LEDs glow on the board.
I would like to know if I am missing something or if someone has faced
a similar issue.
Thanks in advance
Sandeep
Sounds to me like the board is booting up fine but that you IDC10 → DB9 hasn’t been done quite right. Make sure you’ve got a null modem cable and that the wiring really is right. You should see some output within a second or so of the board being powered up…
