When I’m installing Lucid from the image below, it stops in Prepare partitions. I have also made partitions to SD card and even copied minimal lucid on mmcblk0p2. Still install script says: “No root file system is defined”
How to define root file system?
It's best when using the NetInstall method to only define the first
fat16 boot partition... Anything else you'll have to go into the
guided section of the partition-er and actually specify it to use the
other partition you previously created as root...
I had faced same problem.
I found following errror:
"The Installer needs to commit changes to partition tables, but cannot
do so because partions on the following mount points could not be
umounted:
/cdrom
Please close any applications using these mount points.
Would you like the installer to try to umount these partions again ?'
Is failing with /cdrom mounting errors, etc.. Like you mentioned in your email..
I'm heading back home tomorrow from ESC.. (where my beagles are
located) So I won't be able to confirm the /cdrom problem with
ubuntu's own omap NetInstaller till later this week... (i also need to
upload a final 10.04 image to rcn-ee.net too.. ) Although, once
confirmed, all i can do is submit a new bug report on launchpad and
bug my contacts on irc at canonical to push a fix faster...
Netinstall worked fine, it was very slow process, took like 12 hours to complete.
Is there all SGX accelerators and DSP in Lucid in 2.6.33-500-omap kernel?
I installed xserver-xorg-video-omap3 with apt-get after Lucid installation package was done.
Lucid feels a little bit slow eventhough swap files is installed.
What is the difference between Netbook edition and Netbook 2D edition?
complete.
I've been hearing similar reports when installing to the SD card, if
you use an external usb harddrive it is much faster...
package was done.
Nope, but the 2.6.33-500-omap headers are installed so someone just
needs to create a dkms script for it...
I tried Lucid netbook edition installation to external harddrive. Installation was much faster, about 1h.
When I rebooted, I got lot of “Buffer I/O error sda device” and “lost page write due I/O error” messages
sda device is the external hard drive.
Any idea why I’m getting these errors?
How I can make installation to external drive?
Hope you still remember me, I met you at beagle board seminar. I am planning to port Ubuntu 10.4 on to Devkit 8000 board. kindly let me know what are basic steps to be followed.
Please tell me the step by step procedure to load Ubuntu netbook install on a C3 series Beagleboard?
When i fallowed the procedure based on https://wiki.ubuntu.com/ARM/BeagleNetbookInstall but while NAND booting it doesn’t able to read boot.scr.
I am using the Rev C3 board , and i tried to load Ubuntu 10.04 on beagle
i was followed the procedure mentioned in the netbook install method https://wiki.ubuntu.com/ARM/BeagleNetInstall
after that ubuntu live installer screen coming properly, but my keyboard and mouse drivers are not loading so i can not able operate
can any one please tell me what could be the issue…?
