I’ve been trying to connect a wireless card (TRENDNET TEW-624UB) but i’ve been having been unsuccessful.
When I plug the wireless card into my desktop (Ubuntu 9.04), it works without any problems. When I connect the card to my beagleboard through a powered high speed hub, usb0 becomes available to ifconfig. Problem is, iwconfig claims that there are no wireless extensions available on that interface.
After poking around, I found the rt2870 driver is used on my desktop. The firmware for this chipset is included in linux-firmware and I did include this when I build my image.
Upon some further searching, I’ve found that in my desktop setup, /lib/modules/2.6.28-12-generic/kernel/drivers/net/wireless/ has a folder rt2x00 which appears to contain the shared library the kernel would use. The similar directory on my bb only has drivers for zd1211rw.
And I’m stuck. I’m very new to alot of this but I understand “ko”'s are shared libraries, thus copying them from my x86 distro to my ARM distro should not work (right?). I would appreciate any and all advice or suggestions on what to do next.
I have the same problem with a bluetooth card but I figure that if I can figure out one of them, a similar solution will (hopefully) work for the other.
Many thanks,
Christopher Prevoe
