HI,
hi,i am trying to put ubuntu image on sd card it …
since i have previously formatted it I am unable copy fails to it since it tells read only …
i am also unable to reformat it using fdisk again it tells read only can any 1 help me …
thanks in advance
First check a small switch on SD card, this change between read only and writable.
If is not it, then, your SD card seems to be faulty, try use another…
2010/5/5 pramod kr <234pramod@gmail.com>
What are error messages you are getting? Have you checked SD card write protection tab on the side of the card?
-Petri-
