I have a beagleboard-xm
I have prepared a new sd card 8GB and installed a Angstrom image
follow this guide:
http://www.ibm.com/developerworks/linux/library/l-beagleboard-xm/.
Therefore my card has a 2 partitions and Angstrom works right.
Now I would like to know how to install a matrix-gui.
Can you help me?
Best regards
Paolo Preioni (Italy)
I also read the instruction ot http://www.angstrom-distribution.org/demo/beagleboard/
But my query is the same:
After I finish to unpack and boot a demo inage, I don’t understand how to install a matrix-gui.
Preioni Paolo
did u try the following?
opkg install matrix-gui-e matrix-gui-common
2011/10/20 Paolo Preioni <preioni.p@beta-vb.it>
Thank you for the answer.
I just installed matrix_gui
And now?
How I run the matrix_gui?
If I execute /usr/bin# ./matrix_quiE the answer is:
QWSSocket:: … connection refused
no Qt ofr Embedded Linux Server appear to be running.
If you want to run this program as a server, add the “-qws” command-line option.
I also installed qt4-embedded but the result is the same.
execute ./matrix_quiE -qws
If I execute ./matrix_quiE -qws, I have a DVI monitor black and if I move the mouse I see two cursor and where I move the cursor re-appear the Angstrom desktop.
Preioni Paolo
maxtrix-gui runs as a service, try the following:
/etc/init.d/matrix-gui-e start
2011/10/21 Paolo Preioni <preioni.p@beta-vb.it>
thank you for the answer
I try /etc/init.d/matrix-gui-e start and the answer is:
Calibrating touchscreen … ts_calibrate: not found
Ok, because I have a beagleboard-xm connected only a DVI monitor.
Therefore I think that I re-build my project for my hardware: correct?
I follow the guide
http://processors.wiki.ti.com/index.php/How_to_Build_the_Matrix_GUI
and now?
i have found a patch to use matrix-gui with dvi:
https://gforge.ti.com/gf/project/matrix_gui/tracker/?action=TrackerItemEdit&tracker_item_id=1388
I don’t know how apply the patch indicated in the link
moreover I don’t know how disable the touchscreen
