So I think I've got this right, but I want to make sure.
After reading: http://focus.ti.com/lit/ds/symlink/dm3730.pdf on page 117 I see the following:
Table 3-1. Absolute Maximum Rating over Junction Temperature Range
I(clamp) Clamp current for an input or output ?20 20 mA
Is this saying that any single IO PIN/BALL can source and sink at most 20mA?
Jim
Ok read some more of that document. And on page 26 I see some charts that indicate "Output buffer strength" for the various balls/pins. For the various GPIO pins I see numbers ranging from 1,4 and 8 mA.
So I guess I'm a bit confused. How much can any given GPIO pin source and sink?
Sink 20mA, source either 1,4 or 8mA depending upon the pin?
What document and section do I find this information?
Thank you again,
Jim
Jim
You received this message because you are subscribed to the Google Groups "Beagle Board" group.
To post to this group, send email to beagleboard@googlegroups.com.
To unsubscribe from this group, send email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/beagleboard?hl=en.
----- End message from jimnorton@jimnorton.org -----
Some of the pins can vary based on the selected drive strength via the SW. So, making a general statement as to the current drive strength of the pins is not a good way to look at it. If you want the pin to drive an LED, then it won’t. 8mA is generally speaking the max it can drive. There is a a number that is stated as to the max you can try to rive it without damage. The information is found in the datasheet on a per pin basis.
Thanks Gerald. How much can the GPIO pins sink?
I appreciate your help.
Jim
it won't. 8mA is generally speaking the max it can drive. There is a a
sink?
Thank you again,
Jim
20mA?
Jim
----- End message from gerald@beagleboard.org -----
Most all pins can be a GPIO pin, but they are other functionsas well. Best case is 8mA.
