regards.
My BB-Xm, not boot.
previously it operated normally with Ubuntu and of a moment to other, stopped working. it is weird!
When it energized by the DC connector to 5V / 1A, in the plaque of BB-Xm only it turns on diode 5 (green), constant but not blinks.
I made the following tests:
I changed the adaptor DC.
I supplied voltage to the board for the port mini usb / otg.
I bought a new MicroSd and I installed the operative system Ubuntu as the indicates page:
http://elinux.org/BeagleBoardUbuntu#Method_1:_Download_a_Complete_Pre-Configured_Image
I connected the board to the pc, by the serial cable to usb, using the terminal emulator with command: sudo putty /dev/ttyUSB0. (but i do not know if because the cable not is crossed or the port disabled)
What should I do?
in Colombia there will be a certified site? for maintenance.
I appreciate any cooperation.
