Hello everybody! I was happily enjoying my BeaglBoard xM Rev C until I accidentally hit the board slightly, causing the sd card to eject.
Since then I have been getting the following every time I power the BeagleBoard , with no DVI signal output (same result with or without sd card):
- the red led D13 flashes once
- the green led D14 flashes once
- the green led D5 stays on
Thinking that I might have damaged the file system during the eject, I followed the the instructions below in order to recreate a bootable sd card:
[http://code.google.com/p/beagleboard/wiki/HowToGetAngstromRunning](http://code.google.com/p/beagleboard/wiki/HowToGetAngstromRunning)
I was not successful. So I found the following instructions from circuitco where they provide the sd card image that is shipped with the BeagleBoard xM Rev C.
http://circuitco.com/support/index.php?title=BeagleBoard-xM#Image_Files
I was once again unsuccessful.
I would be able to order a new board but I first want to make sure that the current board is dead. Is there any way I could test the board and find out if the problem is hardware related?
Thanks!!
