Thanks all for your reply,
@Kate No i didn't face the same problem with Angstrom
@Robert
Here is the log and I have tried other devices but they didn't work
Texas Instruments X-Loader 1.5.0 (Jun 24 2011 - 01:31:59)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 04 2011 - 12:36:16)
OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
No EEPROM on expansion board
Die ID #490c00029ff800000160716417025019
Hit any key to stop autoboot: 3 2 1 0
The user button is currently NOT pressed.
SD/MMC found on device 0
reading uEnv.txt
143 bytes read
Importing environment from mmc ...
reading boot.scr
454 bytes read
Running boot.scr script from mmc ...
## Executing script at 80200000
Debug: Demo Image Install
reading uImage
3294380 bytes read
reading uInitrd
3704019 bytes read
## Booting kernel from Legacy Image at 80300000 ...
Image Name: 2.6.39.2-x2
Data Size: 3294316 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 81600000 ...
Image Name: initramfs
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 3703955 Bytes = 3.5 MiB
Load Address: 00000000
Entry Point: 00000000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.39.2-x2 (root@beagle-256mb-0) (gcc
version 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu4) ) #1 SMP Fri Jun 24
12:53:31 UTC 2011
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Beagle expansionboard: none
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x10000
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0dc3000 s10016 r8192
d14560 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 125440
[ 0.000000] Kernel command line: console=ttyO2,115200n8
console=tty0 root=/dev/mmcblk0p2 rootwait ro vram=12MB
omapfb.mode=tv:pal omapdss.def_disp=tv fixrtc buddy=none mpurate=auto
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6,
262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
[ 0.000000] allocated 2097152 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't
want memory cgroups
[ 0.000000] Memory: 494MB = 494MB total
[ 0.000000] Memory: 485668k/485668k available, 38620k reserved, 0K
highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xe0800000 - 0xf8000000 ( 376 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0062000 ( 360 kB)
[ 0.000000] .text : 0xc0062000 - 0xc0887670 (8342 kB)
[ 0.000000] .data : 0xc0888000 - 0xc08fbf60 ( 464 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0,
CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] NR_IRQS:410
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] omap_hwmod: gpt12_fck: missing clockdomain for
gpt12_fck.
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns,
wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000671] Calibrating delay loop... 484.21 BogoMIPS (lpj=1892352)
[ 0.031799] pid_max: default: 32768 minimum: 301
[ 0.032012] Security Framework initialized
[ 0.032104] AppArmor: AppArmor initialized
[ 0.032348] Mount-cache hash table entries: 512
[ 0.033081] Initializing cgroup subsys ns
[ 0.033111] ns_cgroup deprecated: consider using the
'clone_children' flag without the ns_cgroup.
[ 0.033142] Initializing cgroup subsys cpuacct
[ 0.033203] Initializing cgroup subsys memory
[ 0.033264] Initializing cgroup subsys devices
[ 0.033294] Initializing cgroup subsys freezer
[ 0.033416] CPU: Testing write buffer coherency: ok
[ 0.033691] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver,
5 counters available
[ 0.034423] Brought up 1 CPUs
[ 0.034454] SMP: Total of 1 processors activated (484.21 BogoMIPS).
[ 0.034942] devtmpfs: initialized
[ 0.037597] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va
for l4_core
[ 0.037658] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va
for l4_per
[ 0.037689] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va
for l4_wkup
[ 0.050842] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
[ 0.062896] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
[ 0.074951] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
[ 0.076446] print_constraints: dummy:
[ 0.076751] NET: Registered protocol family 16
[ 0.076965] GPMC revision 5.0
[ 0.077880] OMAP GPIO hardware version 2.5
[ 0.078033] OMAP GPIO hardware version 2.5
[ 0.078155] OMAP GPIO hardware version 2.5
[ 0.078277] OMAP GPIO hardware version 2.5
[ 0.078399] OMAP GPIO hardware version 2.5
[ 0.078521] OMAP GPIO hardware version 2.5
[ 0.079650] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.080749] OMAP3 Beagle Rev: xM C
[ 0.084869] Found NAND on CS0
[ 0.084899] Registering NAND on CS0
[ 0.085113] Unable to get DVI reset GPIO
[ 0.085174] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.087646] Could not look up mcpdm hw_mod
[ 0.087707] Could not look up aess hw_mod
[ 0.087890] OMAP DMA hardware revision 5.0
[ 0.094665] bio: create slab <bio-0> at 0
[ 0.095947] SCSI subsystem initialized
[ 0.097442] usbcore: registered new interface driver usbfs
[ 0.097564] usbcore: registered new interface driver hub
[ 0.097808] usbcore: registered new device driver usb
[ 0.107971] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.110473] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.110534] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.111022] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.114044] print_constraints: VUSB1V5: 1500 mV normal standby
[ 0.114532] print_constraints: VUSB1V8: 1800 mV normal standby
[ 0.114929] print_constraints: VUSB3V1: 3100 mV normal standby
[ 0.116821] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.117614] print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV
normal standby
[ 0.118072] print_constraints: VDAC: 1800 mV normal standby
[ 0.118469] print_constraints: VDVI: 1800 mV normal standby
[ 0.119018] print_constraints: VSIM: 1800 <--> 3000 mV at 1800 mV
normal standby
[ 0.119354] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.126953] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[ 0.127929] Advanced Linux Sound Architecture Driver Version
1.0.24.
[ 0.128601] NetLabel: Initializing
[ 0.128631] NetLabel: domain hash size = 128
[ 0.128662] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.128723] NetLabel: unlabeled traffic allowed by default
[ 0.129028] Switching to clocksource 32k_counter
[ 0.133483] Switched to NOHz mode on CPU #0
[ 0.142761] AppArmor: AppArmor Filesystem Enabled
[ 0.153625] musb-hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 0.157196] musb-hdrc musb-hdrc: USB OTG mode controller at
fa0ab000 using DMA, IRQ 92
[ 0.157745] NET: Registered protocol family 2
[ 0.158111] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 0.159210] TCP established hash table entries: 16384 (order: 5,
131072 bytes)
[ 0.159606] TCP bind hash table entries: 16384 (order: 5, 131072
bytes)
[ 0.159973] TCP: Hash tables configured (established 16384 bind
16384)
[ 0.160003] TCP reno registered
[ 0.160003] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.160064] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.160552] NET: Registered protocol family 1
[ 0.161315] RPC: Registered udp transport module.
[ 0.161376] RPC: Registered tcp transport module.
[ 0.161376] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 0.161682] Trying to unpack rootfs image as initramfs...
[ 0.529510] Freeing initrd memory: 3616K
[ 0.530456] PMU: registered new PMU device of type 0
[ 0.530700] cpufreq-omap: transition: 600000 --> 800000
[ 0.531005] omap_dsp_init: 600000 bytes @ 9ee00000
[ 0.531433] audit: initializing netlink socket (disabled)
[ 0.531524] type=2000 audit(0.554:1): initialized
[ 0.675964] VFS: Disk quotas dquot_6.5.2
[ 0.676452] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.680114] Registering unionfs 2.5.9 (for 2.6.39-rc5)
[ 0.681488] fuse init (API version 7.16)
[ 0.682525] Btrfs loaded
[ 0.682586] msgmni has been set to 955
[ 0.684051] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 254)
[ 0.684112] io scheduler noop registered
[ 0.684112] io scheduler deadline registered
[ 0.684204] io scheduler cfq registered (default)
[ 0.746337] OMAP DSS rev 2.0
[ 0.911132] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.912261] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a
OMAP UART0
[ 0.912506] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a
OMAP UART1
[ 0.912780] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a
OMAP UART2
[ 1.740844] console [ttyO2] enabled
[ 1.744689] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a
OMAP UART3
[ 1.758087] brd: module loaded
[ 1.764160] loop: module loaded
[ 1.770172] omap2-nand driver initializing
[ 1.774780] No NAND device found.
[ 1.778503] No NAND device found.
[ 1.782135] OneNAND driver initializing
[ 1.786560] usbcore: registered new interface driver cdc_ether
[ 1.792694] usbcore: registered new interface driver rndis_host
[ 1.798919] cdc_ncm: 23-Apr-2011
[ 1.802368] usbcore: registered new interface driver cdc_ncm
[ 1.808746] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 3.824462] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.830627] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 3.838500] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.855743] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.862396] hub 1-0:1.0: USB hub found
[ 3.866394] hub 1-0:1.0: 3 ports detected
[ 3.894927] Initializing USB Mass Storage driver...
[ 3.900146] usbcore: registered new interface driver usb-storage
[ 3.906433] USB Mass Storage support registered.
[ 3.914031] g_ether gadget: using random self ethernet address
[ 3.920166] g_ether gadget: using random host ethernet address
[ 3.927246] usb0: MAC ba:12:af:ff:30:0d
[ 3.931243] usb0: HOST MAC 16:38:60:dc:20:cd
[ 3.935791] g_ether gadget: Ethernet Gadget, version: Memorial Day
2008
[ 3.942718] g_ether gadget: g_ether ready
[ 3.946899] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 3.952545] musb-hdrc musb-hdrc: new USB bus registered, assigned
bus number 2
[ 3.960693] hub 2-0:1.0: USB hub found
[ 3.964630] hub 2-0:1.0: 1 port detected
[ 3.969268] mousedev: PS/2 mouse device common for all mice
[ 3.975830] input: twl4030_pwrbutton as /devices/platform/omap/
omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input0
[ 3.987457] i2c /dev entries driver
[ 3.991638] lirc_dev: IR Remote Control driver registered, major
251
[ 3.998901] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 4.005828] device-mapper: uevent: version 1.0.3
[ 4.011108] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02)
initialised: dm-devel@redhat.com
[ 4.020355] device-mapper: multipath: version 1.3.0 loaded
[ 4.026092] device-mapper: multipath round-robin: version 1.0.0
loaded
[ 4.033508] cpuidle: using governor ladder
[ 4.037841] cpuidle: using governor menu
[ 4.041992] sdhci: Secure Digital Host Controller Interface driver
[ 4.048461] sdhci: Copyright(c) Pierre Ossman
[ 4.054901] omap_hsmmc: probe of omap_hsmmc.1 failed with error -16
[ 4.063934] usbcore: registered new interface driver snd-usb-6fire
[ 4.071502] OMAP3 Beagle/Devkit8000 SoC init
[ 4.085693] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 4.092529] ALSA device list:
[ 4.095642] #0: omap3beagle
[ 4.100036] TCP cubic registered
[ 4.104278] NET: Registered protocol family 10
[ 4.112030] NET: Registered protocol family 17
[ 4.117034] Registering the dns_resolver key type
[ 4.122009] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 3
[ 4.130126] ThumbEE CPU extension supported.
[ 4.134582] Registering SWP/SWPB emulation handler
[ 4.142456] Power Management for TI OMAP3.
[ 4.147430] sr_init: No PMIC hook to init smartreflex
[ 4.152954] smartreflex smartreflex.0: omap_sr_probe: SmartReflex
driver initialized
[ 4.161193] smartreflex smartreflex.1: omap_sr_probe: SmartReflex
driver initialized
[ 4.169403] SmartReflex Class3 initialized
[ 4.178924] clock: disabling unused clocks to save power
[ 4.185394] registered taskstats version 1
[ 4.199676] usb 1-2: new high speed USB device number 2 using ehci-
omap
[ 4.213928] Console: switching to colour frame buffer device 90x35
[ 4.333282] mmc0: host does not support reading read-only switch.
assuming write-enable.
[ 4.348968] regulator_init_complete: VDVI: incomplete constraints,
leaving on
[ 4.360260] Freeing init memory: 360K
[ 4.379669] mmc0: new high speed SDHC card at address 1234
[ 4.390625] hub 1-2:1.0: USB hub found
[ 4.398254] hub 1-2:1.0: 5 ports detected
[ 4.414855] mmcblk0: mmc0:1234 SA04G 3.67 GiB
[ 4.429260] mmcblk0: p1 p2
[ 4.551849] udev[69]: starting version 167
[ 4.692352] usb 1-2.1: new high speed USB device number 3 using
ehci-omap
[ 5.301544] usb 1-2.4: new low speed USB device number 4 using ehci-
omap
[ 5.812011] input: HID 04f3:0103 as /devices/platform/usbhs-omap.0/
ehci-omap.0/usb1/1-2/1-2.4/1-2.4:1.0/input/input1
[ 5.831115] generic-usb 0003:04F3:0103.0001: input,hidraw0: USB HID
v1.10 Keyboard [HID 04f3:0103] on usb-ehci-omap.0-2.4/input0
[ 5.856445] input: HID 04f3:0103 as /devices/platform/usbhs-omap.0/
ehci-omap.0/usb1/1-2/1-2.4/1-2.4:1.1/input/input2
[ 5.875915] generic-usb 0003:04F3:0103.0002: input,hidraw1: USB HID
v1.10 Device [HID 04f3:0103] on usb-ehci-omap.0-2.4/input1
[ 5.895812] usbcore: registered new interface driver usbhid
[ 5.905639] usbhid: USB HID core driver
[ 5.981201] EXT4-fs (mmcblk0p2): INFO: recovery required on
readonly filesystem
[ 5.993103] EXT4-fs (mmcblk0p2): write access will be enabled
during recovery
[ 14.775543] EXT4-fs (mmcblk0p2): recovery complete
[ 16.103515] EXT4-fs (mmcblk0p2): mounted filesystem with ordered
data mode. Opts: (null)
[ 18.531860] usb 1-2: clear tt 4 (8000) error -71
[ 18.587463] usb 1-2: clear tt 4 (8000) error -71
[ 18.604492] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 18.664733] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 18.694824] usb 1-2: clear tt 4 (8000) error -71
[ 18.753173] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 18.786193] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 18.818878] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 18.828125] hub 1-2:1.0: Cannot enable port 4. Maybe the USB cable
is bad?
[ 19.194183] hub 1-2:1.0: cannot disable port 4 (err = -71)
[ 19.423400] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 19.694976] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 19.964569] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 20.379302] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 20.720458] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 20.728881] hub 1-2:1.0: Cannot enable port 4. Maybe the USB cable
is bad?
[ 20.987396] hub 1-2:1.0: cannot disable port 4 (err = -71)
[ 21.215270] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.293426] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.332794] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.375091] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.410644] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.419006] hub 1-2:1.0: Cannot enable port 4. Maybe the USB cable
is bad?
[ 21.510955] hub 1-2:1.0: cannot disable port 4 (err = -71)
[ 21.541961] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.607238] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.645233] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.680541] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.710388] hub 1-2:1.0: cannot reset port 4 (err = -71)
[ 21.716217] hub 1-2:1.0: Cannot enable port 4. Maybe the USB cable
is bad?
[ 21.793853] hub 1-2:1.0: cannot disable port 4 (err = -71)
[ 21.799804] hub 1-2:1.0: unable to enumerate USB device on port 4
[ 21.878814] hub 1-2:1.0: cannot disable port 4 (err = -71)
[ 23.399078] hub 1-2:1.0: hub_port_status failed (err = -71)
[ 23.405212] hub 1-2:1.0: connect-debounce failed, port 4 disabled
[ 24.768920] generic-usb 0003:04F3:0103.0004: can't reset device,
ehci-omap.0-2.4/input1, status -71
[ 24.778808] usb 1-2: clear tt 4 (0100) error -19
[ 25.914611] hub 1-2:1.0: hub_port_status failed (err = -71)
[ 25.920745] hub 1-2:1.0: connect-debounce failed, port 4 disabled
[ 25.957489] hub 1-2:1.0: hub_port_status failed (err = -71)
[ 27.019104] hub 1-2:1.0: hub_port_status failed (err = -71)
[ 27.025268] hub 1-2:1.0: connect-debounce failed, port 4 disabled
Ubuntu 11.04 omap ttyO2
omap login: [ 27.986419] hub 1-2:1.0: hub_port_status failed (err =
-71)
[ 29.407684] hub 1-2:1.0: hub_port_status failed (err = -71)
[ 29.418426] hub 1-2:1.0: hub_port_status failed (err = -71)
omap login:
