hi i have installed the Ubuntu in beagle-board-xm sd card.i have used 4Gb sd card
all sd card partations are done and ubuntu is loaded and at last i have connected the card to beagleboard-xm
and i have connected the mouse and keyboard to beagleboard-xm but it is not working what is the problem i cant understand please help me.
Engineering Sciences
BVRIT | SVECW | VIT | BVRITH
Medical Sciences
VDC | SVCP | VIPER | BVRICE
Did the BeagleBoard boot?
Hari Krishna
Indian Institute of Science
Sounds like broken usb drivers..
Give this image a quick test on a spare microSD card.
http://elinux.org/BeagleBoardUbuntu#BeagleBoard_xM
It'll take you 5 minutes to download, 10 to 'flash' to a microSD and 1
minute to verify.
yes
Medical Sciences
Did you connect a monitor? What’s it showing?
Hari Krishna
ya i have connected to the monitor also it will load Ubuntu and it will ask user name password.
Medical Sciences
Then what isn’t working?
Hari Krishna
to enter user name and password keyboard and mouse is not working
Medical Sciences
Are they detected? What does lsusb return? Try dmesg to see if something went wrong. Do your keyboard and mouse work with the default drivers?
By the way, do the above using SSH. Hook up an ethernet cable and SSH into the board.
Hari Krishna
if usb is broken for him, eth0 is not going to be active, as it's
attached the smsc95xx 4 port hub (and ethernet) usb 2.0 device.
Well, usb might not really be broken. It might simply be some weird incompatibility. If usb is really broken, trying to SSH would really prove that.
Hari Krishna
no they are not detected.if Ethernet connection is give will they work
Medical Sciences
what is SSH
Medical Sciences
Not necessarily. But if you can manage an entry through ethernet, you can debug the issue.
Hari Krishna
Let’s take this discussion off the forum. I’ll PM you
Hari Krishna
Most of the time if usb flat out doesn't work, it's
sprz319e-2.1-erratum... Which a lot of the older images don't have our
workaround enabled by default.
Okay. But, in this case, there’s pretty much nothing else that could be done, isn’t it?
The workaround is enabled in the image i linked too. If it doesn't
work with that image, the board is probally broken.
Regards
Board being broken would be my first vouch.
That’s because I have been using Ubuntu on the same board for a while, across several releases, and never did it fail to recognize a usb device. Most probably the board might be broken or the particular image downloaded might be tampered with (unlikely).
