another try.
I’m following the guide for beginners. I partitioned and formatted a 4GB sd card. Then I downloaded an angstrom image from narcissus. As described in the guide I copied the MLO, u-boot.bin and uImage files into the bootable partition and the rootfs in the other.
As stated in the guide, having a bb_xm I didn’t set any boot args.
But at power up only the power led is on. Nothing else happens.
I also tried to reset with the user button pressed but it doesn’t boot anyway.
There is something else I missed? Should not be enough to put the files into a properly formatted sd card?
I read a lot of guide about beagleboard but each one is different! And I’m quite confusing about the simplest way to boot an angstrom image.
