I’ve just gotten started, and have plugged in the usb, loaded the (Mac OSX) drivers, I can login with :
screen /dev/tty.usb*B 115200
The adapter status is connected and indicates:
RNDIS/Ethernet Gadget is currently active and has the IP address 192.168.7.1.
using DHCP
I can browse to
http://192.168.7.1
“It Works!”
But when I navigate to http://192.168.7.2/ I get no connection.
I can ping and get response to 192.168.7.1 but not 192.168.7.2
Here’s what’s even more confusing to me:
Ifconfig returns:
root@beaglebone:~# ifconfig
eth0 Link encap:Ethernet HWaddr D4:94:A1:91:F9:01
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:40
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
usb0 Link encap:Ethernet HWaddr B6:6A:19:94:AF:5B
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::b46a:19ff:fe94:af5b/64 Scope:Link
RX packets:56 errors:0 dropped:0 overruns:0 frame:0
TX packets:25 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:14200 (13.8 KiB) TX bytes:4507 (4.4 KiB)
my processes:
root@beaglebone:/etc/init.d# ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.9 4348 2440 ? Ss 15:14 0:00 /sbin/init run_
root 2 0.0 0.0 0 0 ? S 15:14 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S 15:14 0:00 [ksoftirqd/0]
root 5 0.0 0.0 0 0 ? S 15:14 0:00 [kworker/u:0]
root 6 0.0 0.0 0 0 ? S< 15:14 0:00 [cpuset]
root 7 0.0 0.0 0 0 ? S< 15:14 0:00 [khelper]
root 8 0.0 0.0 0 0 ? S 15:14 0:00 [kdevtmpfs]
root 9 0.0 0.0 0 0 ? S< 15:14 0:00 [netns]
root 10 0.0 0.0 0 0 ? S 15:14 0:00 [sync_supers]
root 11 0.0 0.0 0 0 ? S 15:14 0:00 [bdi-default]
root 12 0.0 0.0 0 0 ? S< 15:14 0:00 [kintegrityd]
root 13 0.0 0.0 0 0 ? S< 15:14 0:00 [kblockd]
root 14 0.0 0.0 0 0 ? S< 15:14 0:00 [omap2_mcspi]
root 15 0.0 0.0 0 0 ? S 15:14 0:00 [khubd]
root 16 0.0 0.0 0 0 ? S< 15:14 0:00 [musb-hdrc.0]
root 17 0.0 0.0 0 0 ? S< 15:14 0:00 [musb-hdrc.1]
root 18 0.0 0.0 0 0 ? S< 15:14 0:00 [rpciod]
root 19 0.0 0.0 0 0 ? S 15:14 0:00 [khungtaskd]
root 20 0.1 0.0 0 0 ? S 15:14 0:01 [kworker/0:1]
root 21 0.0 0.0 0 0 ? S 15:14 0:00 [kswapd0]
root 22 0.0 0.0 0 0 ? S 15:14 0:00 [fsnotify_mark]
root 23 0.0 0.0 0 0 ? S< 15:14 0:00 [nfsiod]
root 24 0.0 0.0 0 0 ? S< 15:14 0:00 [crypto]
root 30 0.0 0.0 0 0 ? S< 15:14 0:00 [kthrotld]
root 31 0.0 0.0 0 0 ? S< 15:14 0:00 [OMAP UART0]
root 32 0.0 0.0 0 0 ? S< 15:14 0:00 [OMAP UART1]
root 33 0.0 0.0 0 0 ? S< 15:14 0:00 [OMAP UART2]
root 34 0.0 0.0 0 0 ? S< 15:14 0:00 [OMAP UART3]
root 35 0.0 0.0 0 0 ? S< 15:14 0:00 [OMAP UART4]
root 36 0.0 0.0 0 0 ? S< 15:14 0:00 [OMAP UART5]
root 37 0.0 0.0 0 0 ? S 15:14 0:00 [kworker/u:1]
root 40 0.0 0.0 0 0 ? S< 15:14 0:00 [kpsmoused]
root 41 0.0 0.0 0 0 ? S 15:14 0:00 [w1_bus_master]
root 42 0.0 0.0 0 0 ? S< 15:14 0:00 [devfreq_wq]
root 43 0.0 0.0 0 0 ? S 15:14 0:01 [mmcqd/0]
root 45 0.0 0.0 0 0 ? S 15:14 0:00 [jbd2/mmcblk0p]
root 46 0.0 0.0 0 0 ? S< 15:14 0:00 [ext4-dio-unwr]
root 56 0.0 0.5 2908 1456 ? Ss 15:14 0:00 /lib/udev/udevd
root 57 0.0 0.4 4364 1216 ? Ss 15:14 0:00 /lib/systemd/sy
root 97 0.0 0.2 2904 720 ? S 15:14 0:00 /lib/udev/udevd
root 101 0.0 0.7 3820 1820 ? Ss 15:14 0:00 /usr/sbin/connm
root 105 0.2 4.0 47848 10228 ? Ss 15:14 0:03 /usr/bin/node b
root 106 0.2 4.0 14688 10216 ? Ss 15:14 0:03 /usr/bin/python
root 107 0.4 5.0 52340 12876 ? Ss 15:14 0:06 /usr/bin/node /
root 109 0.0 0.4 2724 1028 ? Ss 15:14 0:00 /lib/systemd/sy
avahi 111 0.0 0.6 3084 1536 ? Ss 15:14 0:00 avahi-daemon: r
root 112 0.0 0.4 2968 1196 ? Ss 15:14 0:00 /usr/sbin/crond
999 117 0.0 0.5 2604 1284 ? Ss 15:14 0:00 /usr/bin/dbus-d
avahi 120 0.0 0.1 3084 476 ? S 15:14 0:00 avahi-daemon: c
root 163 0.0 0.4 4396 1192 ? S 15:15 0:00 /usr/sbin/wpa_s
root 257 0.0 0.2 1952 728 tty1 Ss+ 15:15 0:00 /sbin/agetty tt
root 265 0.0 0.0 0 0 ? S 15:21 0:00 [kworker/0:0]
root 266 0.0 0.4 2968 1176 ttyO0 Ss 15:21 0:00 /bin/login –
root 272 0.0 0.2 2904 704 ? S 15:22 0:00 /lib/udev/udevd
root 306 0.0 0.2 2112 708 ? Ss 15:22 0:00 /usr/sbin/udhcp
root 307 0.0 0.6 2920 1592 ttyO0 S 15:24 0:00 -sh
root 319 0.0 0.3 2424 956 ttyO0 R+ 15:41 0:00 ps aux
root@beaglebone:/etc/init.d# ls
avahi-daemon connman dbus-1 hwclock.sh syslog
busybox-udhcpc crond dropbear networking syslog.busybox
I’ve read the FAQ, but I’m stuck at the moment.
trying to access the 192.168.7.2 server and the Cloud9 IDE.
Please advise, and thanks.
