Hello Devs,
I am trying to connect wifi using this M.2 wifi module on BB AI-64. However, with no success.
I am following steps from here.
wpa_suppliment-wlan0.conf file:
ctrl_interface=DIR=/run/wpa_supplicant GROUP=netdev
update_config=1
#country=US
p2p_disabled=1
network={
ssid="abcdefgh"
psk="abcd-alpha-Num3ic"
Command:
sudo wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
The wpa_supplicant output:
debian@BeagleBone:~$ sudo wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
Successfully initialized wpa_supplicant
nl80211: kernel reports: Match already configured
wlan0: CTRL-EVENT-SCAN-FAILED ret=-22 retry=1
^Cnl80211: deinit ifname=wlan0 disabled_11b_rates=0
wlan0: CTRL-EVENT-TERMINATING
Please help me to get through this.
Thank you
Best
Shubham
HI @ss13ms110 looks like the chipset is from broadcom/cypress, i’m grabbing one to see if we can get it to work…
Hi @RobertCNelson
Thank you for the reply.
Indeed it is a chipset from cypress connected to M.2 slot.
The strange thing is, it is connected connected to M.2 slot but not showing in lspci. It is showing in lsusb
debian@BeagleBone:~$ lspci
00:00.0 PCI bridge: Texas Instruments Device b00d
debian@BeagleBone:~$ lsusb
Bus 002 Device 002: ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 04b4:0bdc Cypress Semiconductor Corp. Cypress USB 802.11 Wireless Adapter
Bus 001 Device 004: ID 04b4:bd30 Cypress Semiconductor Corp.
Bus 001 Device 003: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 001 Device 002: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Thank you
Welcome to M.2 E-key! M.2 - Wikipedia
what does dmesg | grep brcm show?
Might just be missing the firmware…
Hi @RobertCNelson
Here is the output:
debian@BeagleBone:~$ dmesg | grep brcm
[ 10.611618] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4373 for chip BCM4373/0
[ 10.618368] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 10.621954] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4373/0 wl0: Oct 25 2017 03:07:25 version 13.10.246.79 (r674291 CY) FWID 01-6d5ea084
[ 10.689863] ieee80211 phy0: brcmf_fws_attach: failed to set bdcv2 tlv signaling
[ 10.907852] usbcore: registered new interface driver brcmfmac
[ 11.250415] ieee80211 phy0: brcmf_cfg80211_add_iface: iface validation failed: err=-16
Regards
Shubham
Hello @RobertCNelson
I found drivers for Cypress module here
I am installing backports-laird-10.54.0.13.tar.bz2
along with firmware laird-lwb5plus-usb-div-firmware-10.54.0.13.tar.bz2
However, when I boot, I no longer see wlan0 in ip link.
The dmesg output is this: (complete output here)
[ 10.531194] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4373 for chip BCM4373/0
[ 10.531261] usbcore: registered new interface driver brcmfmac
[ 10.868593] usb 1-1.3.1: USB disconnect, device number 4
[ 10.937523] brcmfmac: brcmf_usb_dl_cmd: usb_submit_urb failed -19
Please let me know if you have any success.
Thank you
Best
Shubham
