BeagleBone AI fails upgrade to 5.10
New BBAI fan cape installed. updated all scripts then ran update_kernel.sh --lts-5_10.
board fails to boot. Anyway to fix this without reflashing?
serial output:
U-Boot 2019.07-rc4-00001-g607b5b738b (Jul 06 2019 - 21:01:15 -0500), Build: jenkins-github_Bootloader-Builder-127
CPU  : DRA752-GP ES2.0
Model: BeagleBoard.org BeagleBone AI
Board: BeagleBone AI REV A
DRAM:  1 GiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
CTRL_CORE_PAD_I2C1_SDA:    0x00060000
CTRL_CORE_PAD_I2C1_SCL:    0x00060000
CTRL_CORE_PAD_GPMC_A0:     0x00060007
CTRL_CORE_PAD_GPMC_A1:     0x00060007
CTRL_CORE_PAD_VIN2A_D4:    0x0005000f
CTRL_CORE_PAD_VIN2A_D5:    0x0005000f
CM_L4PER_GPIO7_CLKCTRL:    0x00000001
CM_L4PER_I2C1_CLKCTRL:     0x00000002
CM_L4PER_I2C4_CLKCTRL:     0x00000002
CM_L4PER_L4_PER1_CLKCTRL   0x00000001
PM_L4PER_I2C1_WKDEP        0x0000b000
RM_L4PER_I2C1_CONTEXT      0x00000002
PM_L4PER_I2C4_WKDEP        0x0000b000
RM_L4PER_I2C4_CONTEXT      0x00000001
BeagleBone: cape eeprom: i2c_probe: 0x54
Checking (ret 1 bus works) I2C1 bus. ret 1
Checking (ret 1 bus works) I2C4 bus. ret 1
BeagleBone: cape eeprom: i2c_probe: 0x55
BeagleBone: cape eeprom: i2c_probe: 0x56
BeagleBone: cape eeprom: i2c_probe: 0x57
Found device at address 0x57
Net:
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Press SPACE to abort autoboot in 1 seconds
usb_boot is currently disabled
scsi_boot is currently disabled
MMC: no card present
switch to partitions #0, OK
Partition Map for MMC device 1  --   Partition Type: DOS
Part    Start Sector    Num Sectors     UUID            Type
  1     8192            30613504        b0e94ac5-01     83 Boot
Scanning mmc device 1
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
702 bytes read in 1 ms (685.5 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt ...
debug: [uname_r=5.10.41-ti-r12] ...
loading /boot/vmlinuz-5.10.41-ti-r12 ...
10736128 bytes read in 241 ms (42.5 MiB/s)
loading /boot/dtbs/5.10.41-ti-r12/am5729-beagleboneai.dtb ...
195844 bytes read in 5 ms (37.4 MiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
loading /boot/initrd.img-5.10.41-ti-r12 ...
4964593 bytes read in 112 ms (42.3 MiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:4bc0f1 0x88000000] ...
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8fb43000, end 8ffff0f1 ... OK
   Loading Device Tree to 8fb10000, end 8fb42d03 ... OK
ft_fixup_clocks failed for DSP voltage domain: FDT_ERR_NOTFOUND
Starting kernel ...
[    0.039794] /cpus/cpu@0 missing clock-frequency property
[    0.039825] /cpus/cpu@1 missing clock-frequency property
[   79.652862] sdhci-omap 480d1000.mmc: Cannot get pinctrl
[   82.798828] sdhci-omap 4809c000.mmc: no pinctrl state for sdr104 mode
[   82.805389] sdhci-omap 4809c000.mmc: no pinctrl state for ddr50 mode
[   82.811859] sdhci-omap 4809c000.mmc: no pinctrl state for sdr50 mode
[   82.818267] sdhci-omap 4809c000.mmc: no pinctrl state for sdr25 mode
[   82.818267] sdhci-omap 4809c000.mmc: no pinctrl state for sdr12 mode
[   82.818298] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[   82.818298] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[   82.831146] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[   82.844512] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[   82.856811] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[   83.132995] sdhci-omap 480b4000.mmc: Cannot get pinctrl
[   90.468780] cpu cpu0: _opp_add_static_v2: opp key field not found
[   90.475006] cpu cpu0: _of_add_opp_table_v2: Failed to add OPP, -19
[   90.482757] cpu cpu0: OPP table can't be empty
[   90.488708] cpu cpu0: _opp_add_static_v2: opp key field not found
[   90.494934] cpu cpu0: _of_add_opp_table_v2: Failed to add OPP, -19
[   90.502807] cpu cpu0: OPP table can't be empty
[   90.610992] omap_voltage_late_init: Voltage driver support not added
[   91.593749] omapdss error: HDMI I2C Master Error
[   91.668701] OF: graph: no port node found in /ocp/interconnect@4a000000/segment@0/target-module@80000/ocp2scp@0/phy@4000
[   92.687438] omapdss error: HDMI I2C Master Error
[  102.641601] irq 118: nobody cared (try booting with the "irqpoll" option)
[  102.649108] handlers:
[  102.651397] [<247970c2>] irq_default_primary_handler threaded [<02b37555>] regmap_irq_thread
[  102.659881] Disabling IRQ #118
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/mmcblk1p1 does not exist.  Dropping to a shell!
Hi @jostmp there’s a simple fix..
Since your on eMMC, grab the small console image, from here:
then boot, and mount the eMMC ext4 partition and edit /boot/uEnv.txt to the old value..
I’m not sure why the update_kernel.sh script picked that,
Please use these meta packages when updating..
For the bbai, this would be:
sudo apt update
sudo apt install bbb.io-kernel-5.10-ti-am57xx
The issues you see i just fixed on Nov 17th:
Thank You!!
worked first try.
greatly appreciate the quick and accurate response.
