BeagleBone Black - Aborting journal on device mmcblk0p2-8
Good Afternoon,
I am using an image file that is converting any file system into read only, which I understand, is basically corrupting file system. I flash the image on the SD card and run
sudo apt-get update && sudo apt-get install vim
This is giving the following error:
[ 229.949699] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:742: gro up 17, 86 clusters in bitmap, 0 in gd [ 229.962166] Aborting journal on device mmcblk0p2-8. [ 229.970955] EXT4-fs (mmcblk0p2): Remounting filesystem read-only [ 229.978290] EXT4-fs error (device mmcblk0p2) in ext4_reserve_inode_write:4688: Journal has aborted [ 229.989936] EXT4-fs error (device mmcblk0p2): ext4_journal_start_sb:349: Detected aborted journal [ 230.002606] EXT4-fs error (device mmcblk0p2) in ext4_reserve_inode_write:4688: Journal has aborted [ 230.015247] EXT4-fs error (device mmcblk0p2) in ext4_ext_remove_space:2871: Journal has aborted [ 230.027309] EXT4-fs error (device mmcblk0p2) in ext4_reserve_inode_write:4688: Journal has aborted [ 230.039636] EXT4-fs error (device mmcblk0p2) in ext4_ext_truncate:4354: Journal has aborted [ 230.051220] EXT4-fs error (device mmcblk0p2) in ext4_reserve_inode_write:4688: Journal has aborted [ 230.063843] EXT4-fs error (device mmcblk0p2) in ext4_orphan_del:2704: Journal has aborted [ 230.075416] EXT4-fs error (device mmcblk0p2) in ext4_reserve_inode_write:4688: Journal has aborted dpkg: error processing archive /var/cache/apt/archives/python2.7_2.7.6-8ubuntu0.4_armhf.deb (--unpack): unable to securely remove '//usr/share/doc/python2.7/ACKS.gz.dpkg-tmp': Read-only file system
Looking into /etc/fstab:
/dev/mmcblk0p2 / auto errors=remount-ro 0 1
/dev/mmcblk0p1 /boot/uboot auto defaults 0 1
UNCONFIGURED FSTAB FOR BASE SYSTEM
I understand that changing
errors=remount-ro
to
defaults
would solve the problem. Also, I know that fsck and reboot does solve the issue as well. However, I am more interested in getting to know the root cause of this issue. After reading posts online, I starting doing hardware checks. I am using smartmontools, however, SMART tool does not do health check for eMMC. Is there any way I can check the disk drive health? Also, any ideas/help towards troubleshooting would be greatly appreciated. Please let me know if I ma moving in the right path for troubleshooting the problem.
Thanks!
