Hello everyone.
I was trying to set up a beaglebone as a media center using the hdmi output to plug on my TV. The board itself is running debian wheezy with kernel 3.8.13-bone70. I also need to made the wifi dongle WN723 to work, so I followed the instructions on this video Beaglebone Black - USB WIFI & TP LINK WN725N. Everything works, using a usb hub I was able to play media stored in an external hard drive and access the beaglebone using vnc.
But no matter how I tried to configure mplayer, any video played at full screen has a large amount of frames dropped. The overall result is very unpleasant. Searching on the web, if I understood correctly, there is a video driver (sgx) which has some hardware acceleration and I expect this to gave me better results. Unfortunately, it does not work with this kernel version. I tried to follow the steps here http://elinux.org/BeagleBoardDebian#Install_Latest_Kernel_Image and this is the results:
- Upgrade the kernel to version 4.1.13-bone16, ok
- installed the SGX driver, apparently with no errors
- Tried to play the some videos, same results… apparently the driver is not being used.
Anyway, I tried to get the kernel source and recompile the module for the wifi dongle. being unable to get the sources from the beaglebone repository, I tried to download it from kernel.org. Doing so I was able to compile the driver with no errors, but the module is not recognized and there is no wireless connection.
So I ask:
- Is it really possible to improve the video playing experience on beaglebone black by using this SGX drivers, as I had understood?
- How can I get the sources for this specific kernel version, so I would be able to compile the module 8188eu.ko?
- Does someone knows of any SO image with this options already enabled? Lets say, a beaglebone black image focused on media playing, perhaps with xmbc??
- Anyone has some experience or thoughts that would like to share?
Well… that’s all for now… =)
Carlos Novaes
Hello everyone.
BeagleBoardDebian - eLinux.org and this is
the results:
1) Upgrade the kernel to version 4.1.13-bone16, ok
2) installed the SGX driver, apparently with no errors
3) Tried to play the some videos, same results... apparently the driver is
not being used.
So I ask:
1) Is it really possible to improve the video playing experience on
2) How can I get the sources for this specific kernel version, so I would be
Which kernel? uname -r
3) Does someone knows of any SO image with this options already enabled?
xmbc??
4) Anyone has some experience or thoughts that would like to share?
The BeagleBone Black is not designed to be a media player.. It
doesn't have any hardware codec's to do ANY video acceleration.
This is one area where an rPI is going to be a better option. The rPI zero at $5 would probably make the most sense.
Understood. So it will not be an option. Anyway, it was just a funny idea that came into my mind. Maybe I would try with an old CPU that is somewhere in house...
The kernel version for which I could not find the sources, at least by adapting the instructions on the link was 4.1.13-bone16.
Anyway, what would be the standard way to download kernel sources into BBB?
