Hello there,
Ive had it with my internet provider for a while now. I have a free BeagleBone Black and a usb huawei 3G modem laying around though. So I thought- wny not connect the usb modem to BeagleBone Black to get internet, and then connect BeagleBone Black to my router via ethernet to distrubute it further. I was trying to accmplish this approach some time a go by googling around and trying to set up some programs on a debian distro without success…
I was wondering- isnt there any straight forward solution for aplication such as this? Maybe a separate OS even, I dont mind? This is the only task I would like BeagleBone Black to do- get and then distribute internet.
I would really aprichiate any help in here, it would be really great for me to set this up.
I've used 3 or 4 different Huawei usb 3G modems. All worked pretty easily. I'm using an old version of the RCN images with Debian Wheezy and kernel 3.8.13-bone51.
All the tutorials for 3G modem for linux in general works good in BBB. A good one is this:
https://www.thefanclub.co.za/how-to/how-setup-usb-3g-modem-raspberry-pi-using-usbmodeswitch-and-wvdial
And I've tested only one 4G modem. It needed a newer version of usb_modeswitch, which is available in the Jessie images of RCN:
http://elinux.org/BeagleBoardDebian#Debian_Testing_.28jessie.29
I think I had to recompile the kernel because one option was not turned on in the default kernel I used. But I don't remember which one. It was a long time ago and maybe this option is available now.
I haven't "shared" the 3G connection with the ethernet port, but I have already read somewhere that it can be accomplished with firestarter and dhcp3-server (to provide the IP's). Maybe this can help you.
Miguel Aveiro
openwrt maybe?
Thanks for the tips. I was wondering about openwrt, but im not sure either everything is supported there. I could get more pain than usage i fear.
This is very standard stuff. Debian can handle everything you need.
OpenWrt is needed on kit with very restricted memory and flash, and
neither of these are a problem with the BBB.
The kernel is going to have support for most USB 3G modems (just don't
choose a brand new one it's kernel support might still be in development).
Then set up the routing, and put a dhcp server up and off you go. Oh yes,
and remember to enable IPV4 forwarding (google it, as I say this is standard
stuff).
David
Oh yes,and you will need an iptables SNAT rule (again google is your friend).
David
Right now I am trying to use the tutorial from here:
http://crazy-embedder.blogspot.it/2014/12/beaglebone-black-as-3g-router-or.html?m=1
The difference I have other model of the huawei modem (e3131). After I hit lsusb, I dont see the full string like:
Bus 002 Device 005: ID 12d1:1003 Huawei chnologies Co., Ltd. E220 HSDPA Modem / E230/E270/E870 HSDPA/HSUPA Modem
All I see is:
Bus 001 Device 003: ID 12d1:14db Huawei Technologies Co., Ltd.
Dont I have a driver? How can I install it? Is it even available? Tried to google and found nothing.
After i get to the sakis3g config I choose the Huawei stick:
https://lh3.googleusercontent.com/-DmEg3k3NJe4/VLlddzhmZuI/AAAAAAAAAfw/kDCGykbeWng/s1600/huawei.png
And after that I cant connect:
https://lh5.googleusercontent.com/-AIxBrN7xBAE/VLld8bFCucI/AAAAAAAAAf4/1PSQtQ08u3Q/s1600/failed.png
I would really aprichiate any help.
Well a quick google lead me to:-
http://www.raspberrypi.org/forums/viewtopic.php?t=18996
which I suspect will solve your problem (or at least move it forward).
David
I notice you have dropped the beageboard group, I have added it back, please
keep this thread on the group.
David
Sorry for that, ive done it by accident i think.
So I tried to install the network-manager, but it was not fully installed because it run into some errors (I think im not abble to install a single package clean there...). After the restart there is still no eth1 or any other.
Normally I was also always using interface file to config everything.
W dniu 2015-01-16 o 21:02, David Goodenough pisze:
