Hi gyus,
I’m trying to find a solution for this SSH problem, I already tried to use these solutions: https://groups.google.com/forum/#!topic/beagleboard/Ya2qE4repSY , https://groups.google.com/forum/?fromgroups=#!msg/beagleboard/Ya2qE4repSY/u4lvOjF66JEJ
The only way that I’m able to access the command-line on the Beaglebone is using the ‘screen’ command on Mac OS X. I tried to recover the SSH by using the command-line and tried to clean the configuration of the Dropbear too, but I couldn’t make it works.
The only solution that I worked for me was to re-flash the Beaglebone’s MMC and reinstall everything from the beginning.
Is there a way to create a flasher SD image with custom softwares, making easier to reinstall everything?
Or is there a way to reinstalls the SSH server on Beaglebone?
Thanks in advance,
Vitaliano Palmieri Neto
Programmer @ Iceland 2nd Nation
