Hi Dennis,
yes, the board looks similar. Of course I powered with a separate power supply
That’s my board:
https://www.ebay.de/itm/174109565997
Works fine on Windows PC, so it’s not defective.
I like it, brilliant colors, wide angle … but Beaglebone Black is ignoring the touch.
I’m using the current IOT Debian buster image.
lsusb
dmesg
[ 0.000000] Linux version 4.19.94-ti-r64 (voodoo@rpi4b4g-07) (gcc version 8.3.0 (Debian 8.3.0-6)) #1buster SMP PREEMPT Fri May 21 23:57:28 UTC 2021
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] On node 0 totalpages: 130560
[ 0.000000] Normal zone: 1148 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130560 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4c0 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s38988 r8192 d22452 u69632
[ 0.000000] pcpu-alloc: s38988 r8192 d22452 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj
=1990656 rng_core.default_quality=100 quiet video=HDMI-A-1:1024x600@60e
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 437912K/522240K available (13312K kernel code, 1140K rwdata, 4340K rodata, 1024K init, 350K bss, 35176K reserved, 49152K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (14304 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) (1141 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 351 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 42210 entries in 124 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000023] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000044] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000055] OMAP clocksource: timer1 at 24000000 Hz
[ 0.002178] timer_probe: no matching timers found
[ 0.002530] Console: colour dummy device 80x30
[ 0.002560] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 0.002565] This ensures that you still see kernel messages. Please
[ 0.002570] update your kernel commandline.
[ 0.002634] Calibrating delay loop (skipped) preset value… 995.32 BogoMIPS (lpj=1990656)
[ 0.002651] pid_max: default: 32768 minimum: 301
[ 0.002937] Security Framework initialized
[ 0.002952] Yama: becoming mindful.
[ 0.003096] AppArmor: AppArmor initialized
[ 0.003200] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003212] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004307] CPU: Testing write buffer coherency: ok
[ 0.004372] CPU0: Spectre v2: using BPIALL workaround
[ 0.004859] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.025324] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.033232] rcu: Hierarchical SRCU implementation.
[ 0.044461] EFI services will not be available.
[ 0.049236] smp: Bringing up secondary CPUs …
[ 0.049251] smp: Brought up 1 node, 1 CPU
[ 0.049263] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.049270] CPU: All CPU(s) started in SVC mode.
[ 0.051005] devtmpfs: initialized
[ 0.085644] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.086263] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.086288] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.090245] xor: automatically using best checksumming function neon
[ 0.090262] pinctrl core: initialized pinctrl subsystem
[ 0.091594] NET: Registered protocol family 16
[ 0.096804] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.188982] l4_wkup_cm:clk:0010:0: failed to disable
[ 0.229333] audit: initializing netlink subsys (disabled)
[ 0.233348] audit: type=2000 audit(0.224:1): state=initialized audit_enabled=0 res=1
[ 0.238233] OMAP GPIO hardware version 0.1
[ 0.262666] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.289387] raid6: using algorithm neonx8 gen() 0 MB/s
[ 0.289400] raid6: … xor() 0 MB/s, rmw enabled
[ 0.289407] raid6: using neon recovery algorithm
[ 0.297429] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.304424] SCSI subsystem initialized
[ 0.305392] libata version 3.00 loaded.
[ 0.305728] usbcore: registered new interface driver usbfs
[ 0.305787] usbcore: registered new interface driver hub
[ 0.305904] usbcore: registered new device driver usb
[ 0.307886] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.309440] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.310025] pps_core: LinuxPPS API ver. 1 registered
[ 0.310059] PTP clock support registered
[ 0.310932] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.313604] Advanced Linux Sound Architecture Driver Initialized.
[ 0.314391] NetLabel: Initializing
[ 0.314401] NetLabel: domain hash size = 128
[ 0.314406] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.314493] NetLabel: unlabeled traffic allowed by default
[ 0.315623] clocksource: Switched to clocksource timer1
[ 0.477808] VFS: Disk quotas dquot_6.6.0
[ 0.477915] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.478782] AppArmor: AppArmor Filesystem Enabled
[ 0.491878] NET: Registered protocol family 2
[ 0.492892] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.492928] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.492972] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.493029] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.493160] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.493182] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.493546] NET: Registered protocol family 1
[ 0.506702] RPC: Registered named UNIX socket transport module.
[ 0.506712] RPC: Registered udp transport module.
[ 0.506717] RPC: Registered tcp transport module.
[ 0.506722] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.507559] Unpacking initramfs…
[ 0.904997] Freeing initrd memory: 6920K
[ 0.905837] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.909140] Initialise system trusted keyrings
[ 0.909538] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.916799] zbud: loaded
[ 0.924128] NFS: Registering the id_resolver key type
[ 0.924183] Key type id_resolver registered
[ 0.924189] Key type id_legacy registered
[ 0.924207] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.924587] fuse init (API version 7.27)
[ 0.935085] Key type asymmetric registered
[ 0.935100] Asymmetric key parser ‘x509’ registered
[ 0.935207] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.939560] io scheduler noop registered
[ 0.939571] io scheduler deadline registered
[ 0.940136] io scheduler cfq registered (default)
[ 0.940148] io scheduler mq-deadline registered
[ 0.943381] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 0.957377] gpio-of-helper ocp:cape-universal: ready
[ 0.970770] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.974477] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[ 0.984612] console [ttyS0] enabled
[ 0.985791] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[ 0.986774] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 32, base_baud = 3000000) is a 8250
[ 0.987927] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 33, base_baud = 3000000) is a 8250
[ 0.988961] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 34, base_baud = 3000000) is a 8250
[ 0.989907] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 35, base_baud = 3000000) is a 8250
[ 0.993526] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 0.994528] sdhci: Secure Digital Host Controller Interface driver
[ 0.994536] sdhci: Copyright(c) Pierre Ossman
[ 0.995012] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 0.995022] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 0.995586] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.1
[ 0.996199] random: fast init done
[ 0.996556] random: crng init done
[ 1.021158] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.1
[ 1.044894] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.080958] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.084248] mmc0: new high speed SDHC card at address aaaa
[ 1.089817] mmcblk0: mmc0:aaaa SM32G 29.7 GiB
[ 1.091347] mmc1: new high speed MMC card at address 0001
[ 1.097069] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 1.097329] mmcblk0: p1
[ 1.100055] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 1.100713] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 1.101055] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB, chardev (245:0)
[ 1.171468] eqep 48300180.eqep: ver. 1.0
[ 1.171830] eqep 48300180.eqep: count_mode:0
[ 1.171842] eqep 48300180.eqep: invert_qa:1
[ 1.171851] eqep 48300180.eqep: invert_qb:1
[ 1.171860] eqep 48300180.eqep: invert_qi:0
[ 1.171868] eqep 48300180.eqep: invert_qs:0
[ 1.171877] eqep 48300180.eqep: swap_inputs:0
[ 1.171886] eqep 48300180.eqep: QDECCTL:0x0180
[ 1.171894] eqep 48300180.eqep: QPOSINIT:0x00000000
[ 1.171902] eqep 48300180.eqep: QPOSMAX:0xffffffff
[ 1.171909] eqep 48300180.eqep: QPOSCNT:0x00000000
[ 1.171918] eqep 48300180.eqep: omit_interrupt:0
[ 1.171925] eqep 48300180.eqep: QEINT:0x0800
[ 1.171933] eqep 48300180.eqep: QUPRD:0x05f5e100
[ 1.171940] eqep 48300180.eqep: QEPCTL:0x009e write
[ 1.171948] eqep 48300180.eqep: QEPCTL:0x009e read
[ 1.171976] eqep 48300180.eqep: irq:136, clk_rate:100000000
[ 1.172184] eqep 48302180.eqep: ver. 1.0
[ 1.172314] eqep 48302180.eqep: count_mode:0
[ 1.172325] eqep 48302180.eqep: invert_qa:1
[ 1.172333] eqep 48302180.eqep: invert_qb:1
[ 1.172341] eqep 48302180.eqep: invert_qi:0
[ 1.172349] eqep 48302180.eqep: invert_qs:0
[ 1.172357] eqep 48302180.eqep: swap_inputs:0
[ 1.172364] eqep 48302180.eqep: QDECCTL:0x0180
[ 1.172372] eqep 48302180.eqep: QPOSINIT:0x00000000
[ 1.172379] eqep 48302180.eqep: QPOSMAX:0xffffffff
[ 1.172386] eqep 48302180.eqep: QPOSCNT:0x00000000
[ 1.172394] eqep 48302180.eqep: omit_interrupt:0
[ 1.172401] eqep 48302180.eqep: QEINT:0x0800
[ 1.172409] eqep 48302180.eqep: QUPRD:0x05f5e100
[ 1.172416] eqep 48302180.eqep: QEPCTL:0x009e write
[ 1.172423] eqep 48302180.eqep: QEPCTL:0x009e read
[ 1.172443] eqep 48302180.eqep: irq:138, clk_rate:100000000
[ 1.172587] eqep 48304180.eqep: ver. 1.0
[ 1.172716] eqep 48304180.eqep: count_mode:0
[ 1.172726] eqep 48304180.eqep: invert_qa:1
[ 1.172734] eqep 48304180.eqep: invert_qb:1
[ 1.172742] eqep 48304180.eqep: invert_qi:0
[ 1.172750] eqep 48304180.eqep: invert_qs:0
[ 1.172758] eqep 48304180.eqep: swap_inputs:0
[ 1.172765] eqep 48304180.eqep: QDECCTL:0x0180
[ 1.172773] eqep 48304180.eqep: QPOSINIT:0x00000000
[ 1.172780] eqep 48304180.eqep: QPOSMAX:0xffffffff
[ 1.172787] eqep 48304180.eqep: QPOSCNT:0x00000000
[ 1.172795] eqep 48304180.eqep: omit_interrupt:0
[ 1.172802] eqep 48304180.eqep: QEINT:0x0800
[ 1.172810] eqep 48304180.eqep: QUPRD:0x05f5e100
[ 1.172817] eqep 48304180.eqep: QEPCTL:0x009e write
[ 1.172824] eqep 48304180.eqep: QEPCTL:0x009e read
[ 1.172843] eqep 48304180.eqep: irq:140, clk_rate:100000000
[ 1.219737] libphy: Fixed MDIO Bus: probed
[ 1.220724] CAN device driver interface
[ 1.222131] c_can_platform 481cc000.can: c_can_platform device registered (regs=d2925ff0, irq=42)
[ 1.223202] c_can_platform 481d0000.can: c_can_platform device registered (regs=64e7809e, irq=43)
[ 1.279739] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.279755] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 1.280701] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 1.299187] libphy: 4a101000.mdio: probed
[ 1.299216] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.300670] cpsw 4a100000.ethernet: Detected MACID = e4:15:f6:fc:4a:61
[ 1.300828] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 1.300838] cpsw 4a100000.ethernet: ALE Table size 1024
[ 1.300880] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 1.303058] usbcore: registered new interface driver smsc95xx
[ 1.305138] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.305204] ehci-platform: EHCI generic platform driver
[ 1.305584] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.306538] usbcore: registered new interface driver usb-storage
[ 1.310272] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 1.310459] am335x-phy-driver 47401300.usb-phy: Linked as a consumer to regulator.0
[ 1.314116] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 1.314288] am335x-phy-driver 47401b00.usb-phy: Linked as a consumer to regulator.0
[ 1.317903] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 1.317945] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 1.318283] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.318293] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.318302] usb usb1: Product: MUSB HDRC host driver
[ 1.318309] usb usb1: Manufacturer: Linux 4.19.94-ti-r64 musb-hcd
[ 1.318317] usb usb1: SerialNumber: musb-hdrc.1
[ 1.319150] hub 1-0:1.0: USB hub found
[ 1.319214] hub 1-0:1.0: 1 port detected
[ 1.331202] omap_rtc 44e3e000.rtc: already running
[ 1.332017] omap_rtc 44e3e000.rtc: registered as rtc0
[ 1.333704] i2c /dev entries driver
[ 1.337863] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.338505] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 1.342745] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.343329] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.343787] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 1.346440] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.350397] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.358426] gnss: GNSS driver registered with major 242
[ 1.365767] NET: Registered protocol family 10
[ 1.435959] Segment Routing with IPv6
[ 1.436129] mip6: Mobile IPv6
[ 1.436287] NET: Registered protocol family 17
[ 1.436317] can: controller area network core (rev 20170425 abi 9)
[ 1.436413] NET: Registered protocol family 29
[ 1.436511] 8021q: 802.1Q VLAN Support v1.8
[ 1.436592] Key type dns_resolver registered
[ 1.436599] mpls_gso: MPLS GSO support
[ 1.436922] ThumbEE CPU extension supported.
[ 1.436938] Registering SWP/SWPB emulation handler
[ 1.436950] omap_voltage_late_init: Voltage driver support not added
[ 1.445363] registered taskstats version 1
[ 1.445373] Loading compiled-in X.509 certificates
[ 1.445514] zswap: loaded using pool lzo/zbud
[ 1.448830] Btrfs loaded, crc32c=crc32c-generic
[ 1.448948] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.614527] tda998x 0-0070: found TDA19988
[ 1.617625] [drm] forcing HDMI-A-1 connector on
[ 1.617670] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 1.617713] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.617719] [drm] No driver support for vblank timestamp query.
[ 1.680017] Console: switching to colour frame buffer device 128x37
[ 1.683463] tilcdc 4830e000.lcdc: fb0: DRM emulated frame buffer device
[ 1.684366] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[ 1.698384] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 1.699228] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 1.700341] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.701298] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.701415] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.706011] cpu cpu0: Linked as a consumer to regulator.3
[ 1.706123] cpu cpu0: Dropping the link to regulator.3
[ 1.706636] cpu cpu0: Linked as a consumer to regulator.3
[ 1.708992] omap_rtc 44e3e000.rtc: setting system clock to 2021-06-03 08:42:08 UTC (1622709728)
[ 1.710476] ALSA device list:
[ 1.710487] No soundcards found.
[ 1.717076] Freeing unused kernel memory: 1024K
[ 1.717801] Run /init as init process
[ 10.228608] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.122364] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +
BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 11.123103] systemd[1]: Detected architecture arm.
[ 11.149645] systemd[1]: Set hostname to .
[ 12.772283] systemd[1]: Created slice User and Session Slice.
[ 12.777096] systemd[1]: Created slice system-getty.slice.
[ 12.778609] systemd[1]: Listening on Journal Socket.
[ 12.780242] systemd[1]: Listening on Syslog Socket.
[ 12.781411] systemd[1]: Listening on udev Control Socket.
[ 12.793880] systemd[1]: Starting Load Kernel Modules…
[ 12.794186] systemd[1]: Reached target Slices.
[ 13.551222] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro
[ 14.934790] systemd-journald[897]: Received request to flush runtime journal from PID 1
[ 21.876245] net eth0: initializing cpsw version 1.12 (0)
[ 21.961131] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 21.977360] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 21.977380] 8021q: adding VLAN 0 to HW filter on device eth0
[ 24.008936] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 24.009028] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 25.307835] using random self ethernet address
[ 25.307853] using random host ethernet address
[ 25.888979] Mass Storage Function, version: 2009/09/11
[ 25.889003] LUN: removable file: (no medium)
[ 26.287051] using random self ethernet address
[ 26.287069] using random host ethernet address
[ 26.572229] usb0: HOST MAC e4:15:f6:fc:4a:64
[ 26.576519] usb0: MAC e4:15:f6:fc:4a:63
[ 26.588142] usb1: HOST MAC e4:15:f6:fc:4a:66
[ 26.592612] usb1: MAC e4:15:f6:fc:4a:67
[ 26.851877] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 27.090882] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 63.711187] pvrsrvkm: loading out-of-tree module taints kernel.
[ 64.044239] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.sgx on minor 1
[ 70.328069] remoteproc remoteproc0: wkup_m3 is available
[ 70.409424] remoteproc remoteproc0: powering up wkup_m3
[ 70.409455] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 70.409730] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 70.409759] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 70.483401] PM: bootloader does not support rtc-only!
[ 72.580031] remoteproc remoteproc1: 4a334000.pru is available
[ 72.580220] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[ 72.592546] remoteproc remoteproc2: 4a338000.pru is available
[ 72.592751] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
uname -a
Linux beaglebone 4.19.94-ti-r64 #1buster SMP PREEMPT Fri May 21 23:57:28 UTC 2021 armv7l GNU/Linux
ls -als /dev/input
total 0
0 drwxr-xr-x 3 root root 80 Jun 3 08:42 .
0 drwxr-xr-x 16 root root 3480 Jun 3 08:43 …
0 drwxr-xr-x 2 root root 60 Jun 3 08:42 by-path
0 crw-rw---- 1 root input 13, 64 Jun 3 08:42 event0
lsmod
Module Size Used by
pru_rproc 28672 0
irq_pruss_intc 20480 1 pru_rproc
pruss 16384 1 pru_rproc
pm33xx 16384 0
wkup_m3_ipc 16384 1 pm33xx
wkup_m3_rproc 16384 1
remoteproc 57344 3 pru_rproc,wkup_m3_rproc,wkup_m3_ipc
virtio 16384 1 remoteproc
virtio_ring 28672 1 remoteproc
pvrsrvkm 421888 0
pruss_soc_bus 16384 0
usb_f_acm 16384 2
u_serial 20480 3 usb_f_acm
usb_f_ecm 20480 2
usb_f_mass_storage 53248 2
uio_pdrv_genirq 16384 0
uio 20480 1 uio_pdrv_genirq
usb_f_rndis 32768 4
u_ether 20480 2 usb_f_ecm,usb_f_rndis
libcomposite 65536 18 usb_f_ecm,usb_f_acm,usb_f_mass_storage,usb_f_rndis
spidev 20480 0
The project requires the pru units, that works fine.
Touch is eating up my time. And I expect it makes no sense to order other touch displays and the status is still the same.
USB based touch was expected as “best and simple” solution. I need SPI and GPIO for surrounding hardware. That works fine.
HDMI is required to have the possibility to connect “any” monitor. There is 1m distance between BBB and display.
RPI is not an option for me, because I need the PRU’s.
Thanks for help
Kasimir
