I have currently tried to connect a ultrasonic sensor hcsr04 to my BBB with no success.
The support material I was using is to establish the connection and execute a trigger to my sensor and read the output is: https://github.com/luigif/hcsr04.
When I`m executing the ./hcsr04 file I receive accordingly the being msg: >> Initializing PR >> Executing HCSR-04 code, which after it seems to wait for the signal to be triggered but never receives one.
Could you give me some advises? or if you experience working with this model of sensor and have some tips?
The sensor is expecting a 5V signal on the trigger input and generates a 5V signal on echo.
You are feeding a 3.3V signal from the BBB and accepting a 5V signal from the sensor.
Will the output of the BBB, 3.3V, be seen as a 5V input by the sensor?
Will the 5V signal from the sensor fry the gpio pin which is expecting a max voltage of 3.3V?
This is just looking at the voltages and not considering currents, dig out the spec sheets for the sensor to see what the voltage/currents are that it is expecting.
The MOSFET level shifters will transform the 3.3V to 5V and vice versa.
Transistors/resistors will do the same operation.
Chad
vol = 5V;
cur = 15mA;
As Chad said if I will attach a resistor between the the sensor echo and BBB will perform the level shift accordingly.Thus, as I previously mention I have attached a 1kohm resistor between the sensor pin echo and BBB so I could convert the voltage to the BBB expected 3.3V, as far as my calculations showed with a 1KOHM resistor.But will be the sensor satisfied if I have plug it in the VDD_5V from the BBB?
5V signal on echo.
from the sensor.
The cmos threshold is 75% of VCC, so 25% of 5 volts is 1.25 volts,
which gives a desired 1 threshold of 3.75 volts on the sensor.
Not likely to see the signal as a 1.
Yes. See the warnings in the manual.
TI (and others) make unidirectional (can be switched for direction)
level translators that protect both sides of the load and translate
logic levels. The part number (typical) is something on the order of
74LVC8T245, IIRC. I'd recommend them highly. There are DIP packages
more suitable for breadboards.
Transistors can work, as can resistors, but the packaged device is a
neater solution.
I don’t think that I said that.
I gave you some thinking material to think about.
But I did miss saying “transistor/resistor circuit”, the circuit disappeared between the brain and the fingers.
Chad
Hi, did you ever figure out the problem? I’m also using luigif’s example and I have the same problem where the code just waits for an interrupt and never receives it…
Hi, even I was facing the same issue wherein my code was waiting for the interrupt, then when I started to debug the hardware connections, I found that I had interchanged the connections for echo & trigger pins, so after rectifying the connections, the code works fine and I am getting the distance output prints.
