Ryan
July 1, 2014, 12:57pm
1
I just recently changed to a static IP on my Beaglebone black. I am trying to follow a guide on creating a web server with my Beaglebone black. Currently running Debian Wheezy instead of Angstrom like I was doing previously.
The link to the guide: http://www.element14.com/community/community/designcenter/single-board-computers/next-gen_beaglebone/blog/2013/11/20/beaglebone-web-server–setup
If there is a better guide for creating a web server with Debian Wheezy… I’d also love to see it.
I am very new to Linux, and now with Debian running, I am a little stuck… The static IP I set is working fine, since I’ve been able to connect to it… so I don’t really think it could be the static IP, I think I may just be using an incorrect method for getting the “opkg update.”
Response For getting the “opkg update”:
root@beaglebone:~# sudo apt-get update
Err http://ftp.us.debian.org wheezy Release.gpg
Could not resolve ‘ftp.us.debian.org ’
Err http://ftp.us.debian.org wheezy-updates Release.gpg
Err http://beagle.s3.amazonaws.com wheezy-bbb Release.gpg
Could not resolve ‘beagle.s3.amazonaws.com ’
Err http://security.debian.org wheezy/updates Release.gpg
Could not resolve ‘security.debian.org ’
Reading package lists… Done
W: Failed to fetch http://ftp.us.debian.org/debian/dists/wheezy/Release.gpg Could not resolve ‘ftp.us.debian.org ’
W: Failed to fetch http://ftp.us.debian.org/debian/dists/wheezy-updates/Release.gpg Could not resolve ‘ftp.us.debian.org ’
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/Release.gpg Could not resolve ‘security.debian.org ’
W: Failed to fetch http://beagle.s3.amazonaws.com/debian/dists/wheezy-bbb/Release.gpg Could not resolve ‘beagle.s3.amazonaws.com ’
W: Some index files failed to download. They have been ignored, or old ones used instead.
I’m a big noob, and I really appreciate any help you have to offer.
Ryan
What are you using for /etc/resolv.conf?
I'm wondering if i should just add google's dns settings by default..
# Use Google public DNS server:
nameserver 8.8.8.8
nameserver 8.8.4.4
Ryan
July 1, 2014, 1:08pm
3
I added those nameserver, but I still have the same result…
I have two nameservers currently in the /etc/resolve.conf that aren’t the Google public DNS servers that you listed.
Of course, i forgot the second question as i was running out of the door..
What interface? eth0 or usb0?
Ryan
July 1, 2014, 1:29pm
5
No problem, thank you for helping me in a bad time…
eth0… I never did re-comment out the usb0, I was a little bit confused after reading a few guides on setting a static IP for if I was suppose to comment out the usb0 after un-commenting and using the eth0
I tried doing a shutdown to see if that could have been the problem, so I went back in to check the /etc/resolve.conf and saw that it became empty for some reason?
It get's overwritten on bootup..
Add this to your iface: for eth0:
dns-nameservers 8.8.8.8 127.0.0.1
Ryan
July 1, 2014, 1:44pm
7
Added it, then tried the update again, no changes in the response:
auto eth0
iface eth0 inet static
address 192.168.1.61
netmask 255.255.255.0
gateway 192.168.1.83
auto eth0
Did you then do "ifdown eth0" followed by "ifup eth0"? Alternatively
reboot.
You can check it worked by looking in /etc/resolv.conf.
David
Ryan
July 1, 2014, 1:53pm
9
Just tried the ifdown and ifup, that went fine, but the /etc/resolve.conf is still completely empty.
The answer is that it should be dns-nameserver not dns-nameservers. To add
multiple servers add multiple lines.
David
Ryan
July 1, 2014, 2:08pm
11
Okay, I made that change.
Ryan
July 1, 2014, 2:12pm
12
Still no changes with the get update.
can you ping the gateway from the bbb?
Ryan
July 1, 2014, 2:31pm
15
Changed the gateway address, and now it works…
