Hi Chu.
As my modification also solves the issue, your assumption about
your fix (a high level at J4.1/B_UART0_RX (U15.2/1A)) is not true.
Sorry, J1.4 is the correct pin.
I've now done tests with a stronger pulldown (1k in parallel with R165=
990 ohm) and a short directly to DGND/VDD_3V3B (I'll post details later,
find them at Mikini Services » beaglebone black).
These tests confirm that B_UART0_RX can't be pulled down/up, to prevent
the failure to occur. But forming a stable voltage on the input using a
voltage divider (also using 0 ohm= short circuit!) does solve the
problem. That is; whether we form a stable 0.58V or a stable 3.3V on
B_UART0_RX the system will always boot.
Does anybody have definite confirmation (by scope measurements) that
U15.6 (1Y) really is flickering during early power? It would be exiting
to do some experiments showing how it is affected by the U15.3 (1A)
input. I think that is the core of this issue.
We removed the R165 which is the pull down resistor on the
UART0_RX line. The UART0_RX is around 1.4V and sometimes
floating. We also checked the device tree. The internal pull up
of the UART0_RX is turned on.
[UART0_RX on 1.4V or floating]
Peculiar, as it should never float.
I haven't been able to replicate that measurement. I got 3V3 on
UART0_RX (the one without B_, on the cpu side), except in early power
up. I see the voltage flickering shortly just after power is applied,
and in the same instance that kernel is loaded (USR0-USR3 leds starts
lighting up) there also some activity.
Are you sure that you actually did measure on U15.6? It isn't easy to
place the probes right on those small pads.
We do not know why the UART0_RX is not getting 3.3V, can you
please check the voltage on both UART0_TX and UART0_RX when U15
is removed?
I'll definitely look into this tomorrow. Including taking this
measurement.
Here they are, I see nothing unexpected here when things are static. I
also checked the U15 supply, which seems to be ok.
* BBB measurements on terminals of removed U15
** Device Under Test:
Modified Beaglebone Black produced by CircuitCo (PCB REV B6, serial
007142901445, marked "beaglebone"+ beagle logo and
"beagleboard.org").
Modified by removing U15 (uart0 buffer chip: SN74LVC2G241) and its
decoupling capacitor C155.
** Equipment
*** Multimeter
Brymen Elma BM515CF MOBILE LOGGER, MFG.#: 063391676.
*** Power Supply Unit
Huawei HW-050200E3W, output 5V 2A, USB A-connector. Danish plug.
Sourced from Huawei E589 mobile wifi.
*** Power Cable
20 cm no-name USB A male connector to USB Mini-B male connector.
** Procedure
Apply power to BBB through USB Mini-B connector.
Use multimeter to measure voltage levels on exposed U15 terminals
and related supply lines to check possible supply voltage drop.
COM probe fixed at DGND on decoupling capacitor (terminal C155.DGND
farthest from PCB edge).
** Measurements
C155.VDD_3V3B: 3.352V (terminal nearest to PCB edge)
U15.1: _1OE = 0V
U15.2: 1A = 0V
U15.3: 2Y = floating (flickering +-0.000,50V)
U15.4: GND = 0V
U15.5: 2A = UART0_RX = 3.335V
U15.6: 1Y = UART0_TX = 3.195V
U15.7: 2OE = 3.352V
U15.8: VCC = 3.352V
J1.1 = DGND = 0.000,02 V
P2.20 = GND5 = 0.000,02 V
FB4.1 = VDD_3V3B = 3.351 V
Regads,
Even more regads,
Mikkel
,= ,-_-. =.
((_/)o o(\_))
\_/
