Sorry that this is probably a dumb question, but is it possible to not blow
away the partition table since I just want to swap the MLO and u-boot.img?
Using dd, just re-write them to the microSD... The partition table is
safe at another location..
I'm just running the standard image on a Beagle Bone Black that does not
have an eMMC or hdmi chip. I assumed it was busy because I was trying to
reprogram the disk while on an OS that was using the disk?This was the error:
Checking that no-one is using this disk right now ...
BLKRRPART: Device or resource busyThis disk is currently in use - repartitioning is probably a bad idea.
Umount all file systems, and swapoff all swap partitions on this disk.
Use the --no-reread flag to suppress this check.Disk /dev/mmcblk0: 121008 cylinders, 4 heads, 16 sectors/track
sfdisk: ERROR: sector 3069576189 does not have an msdos signature
/dev/mmcblk0: unrecognized partition table type
Old situation:
No partitions found
New situation:
Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0Device Boot Start End MiB #blocks Id System
/dev/mmcblk0p1 * 1 3780 3780 3870720 83 Linux
/dev/mmcblk0p2 0 - 0 0 0 Empty
/dev/mmcblk0p3 0 - 0 0 0 Empty
/dev/mmcblk0p4 0 - 0 0 0 Empty
Successfully wrote the new partition table
ah, sfdisk is just noisly, it worked ^^^^...
Re-reading the partition table ...
later versions don't show this extra stuff...
I have the serial output after the last test, but not from the test where I
did not recreate the partition table.U-Boot 2015.10-rc2-00001-g5879130-dirty (Oct 09 2015 - 15:52:49 +0000)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Reset Source: Global external warm reset has occurred.
Using default environmentNet: <ethaddr> not set. Validating first E-fuse MAC
cpsw
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
This looks fine, based on where you stopped... it was searching for
the microSD card...
