BeagleBone Black - getting started
I have just bought BeagleBoneBlack (RevC3).
Test 1: using the board with monitor (HDMI)
I going throught BeagleBone Black System Reference Manual and I got some issues.
3.4.2 Connecting Up the Board, page 21.
  • data is not properly aligned with my monitor. It looks like some letters are cut.
    How can I fix it?
  • I can’t see the desktop screen (the login screen is available alll the time). How should I run desktop screen?
Test 2: Connect the board directly to my PC (Windows) using USB.
I wanted to run first project:
https://docs.beagleboard.org/latest/intro/beagle101/blinkLED.html#blinkled
I ran VS Code (192.168.7.2:3000).
It looks ok but I can write in the Terminal. My keyboard is working - I see typing letters in the file window. Only terminal do not work.
Second strange thing is that red rectangle with error appered.
How can I write something in the terminal?
And why the error occured?
Thank you.
The HDMI issue is almost certainly caused by your monitor, it’s something called HDMI Overscan - Overscan - Wikipedia
There is likely a setting on your monitor itself that will be “Scan-only” or “Dot-by-dot” or something like that depending on the brand. Some will also just list it as an aspect ration setting (16:9). That tells the monitor to not do Overscan and show the image as the device is trying to display it.
If your monitor doesn’t have that, there may be some SW fixes but usually it’s best to fix it with the display itself. (HDMI Overscan Linux) is the term to google here.
For Test #2, can you share a screenshot? Were you able to login past the terminal prompt initially ? I’m not sure what you mean by a red rectangle.
Overscan and now I know…thank you.
@miszka , I read over the documents, some, that was listed at the WikiPedia site online from @Grippy98 .
Maybe add 5% to 10% of scanned area to your ratio.
Right now and this is just a reminder, please view this idea: https://gitlab.freedesktop.org/drm/kernel/-/blob/drm-next/arch/arm/boot/dts/ti/omap/am335x-boneblack.dts?ref_type=heads .
I say use the openbeagle.org Linux instead of the gitlab.freedesktop.org/ one on gitlab.
Hey!
I am interested in HDMI output, i.e. thus trying here: xrandr --output HDMI1 --auto is a command one can use to automatically make it “work.”
Also, if the auto does not do it: xrandr --output HDMI1 --mode YOUR_RESOLUTION
Where YOUR_RESOLUTION is the resolution of your 1:1.
P.S. I am more interested in this conversation than helpful most likely.
Again,
Me here…I thought about it.
  1. If you cannot see a desktop, add one. I used to use xfce4 to test things.
    a. that would be a command of: sudo apt install xfce4
  2. That command will create your desktop.
    b. There are lighter desktops available like openbox which is a windows manager…
  3. Debian: Getting Started with the BeagleBone Black - Linux Guides - Electronic Component and Engineering Solution Forum - TechForum │ DigiKey
    c. That link should help a bit.
P.S. I am not sure about VS Code on the Buster image, i.e. as Buster is EOL.
https://wiki.debian.org/Openbox
and…
Stable is bookworm: https://wiki.debian.org/DebianReleases
Good luck!
Regarding the overscan issue, most monitors come with a auto-resize button
you can press for it to figure out the settings required to display the source correctly.
Press the magic button and it should align itself to your Beagle proper.
… or am I thinking VGA displays, I forget.
Hi, Thanks for very fast reply.
Test 1
I will investigate this ‘overscan’ issue.
What about that I Desktop screen didn appear and I see that login screen all the time?
Test 2
Screenshot below.
You installed the IOT image, you are free to install your own desktop on that image.
I did not installed anything.
I have just powered up the board and go through BeagleBone Black System Reference Manual.
In the description of ‘Blink LED’ example I mentioned above there is information about preinstalled Linux.
Status of issues:
Issue 1.1 - HDMI Overscan problem solved
Issue 1.2 - I can’t see the desktop screen (the login screen is available alll the time). How should I run desktop screen?
Issue 2.1 - I ran VS Code (192.168.7.2:3000) but I can’t write in the Terminal. My keyboard is working - I see typing letters in the file window. Only terminal do not work.
Issue 2.2 - error “Failed to write to ‘state settings’. ENOSPC: no space left on device, write.” appered.
Update:
I resolved Issue 2.1 and Issue 2.2
I am going to make short explanation. Maybe it helps somebody.
Issue 2.1 and Issue 2.2 were related to memory issues.
Cloud9 started but when I was typing in the terminal the error occured. When I click RUN button another error occured.
Below you can see screenshoots.
Both errors were related to memory.
I checked memory and I was very surprised. The board is new and the system on the MMC took up 3.4GB:
0 /dev
0 /proc
0 /sys
4.0K /media
4.0K /mnt
4.0K /srv
16K /lost+found
20K /root
28K /home
40K /tmp
1.6M /run
3.5M /etc
6.2M /sbin
8.5M /bin
26M /boot
219M /lib
378M /opt
1003M /usr
1.8G /var
3.4G /
Therefore almost all memory of MMC was used. I was looking for something what I could remove (I’m just starting to learn how to work with Linux). I cleard some logs files in /var/log directory.
The current status:
0 /dev
0 /proc
0 /sys
4.0K /media
4.0K /mnt
4.0K /srv
16K /lost+found
20K /root
40K /home
44K /tmp
1.6M /run
3.5M /etc
6.2M /sbin
8.5M /bin
26M /boot
219M /lib
224M /var
378M /opt
1003M /usr
1.9G /
Currently, I can write in the Cloud9 terminal. I can Run examples. The is no issues with the memory. Currenty I get error: “gdbserver not available”. I am trying to make Internet connection with my BeagleBone Black…
Status of issues:
Issue 2.1 - I ran VS Code (192.168.7.2:3000) but I can’t write in the Terminal. My keyboard is working - I see typing letters in the file window. Only terminal do not work. problem solved
Issue 2.2 - error “Failed to write to ‘state settings’. ENOSPC: no space left on device, write.” appered. problem solved
Issue 2.3 - gdbserver not available
Additional questions are,
  1. why NEW BeagleBone Black board have overflowing memory which prevented the example projects from running?
  2. Why getting started manual and getting started section at beaglebone webpage not say anything about Cloud9 ide? It is not supported. Is there any official getting started for Cloud9 and BeagleBone? Or any advices how to change it properly to e.g. VS Code?
BB is a victim of a big tech bully that shut cloud9 ide down to force those using it onto cloud based tools.
What BB did do is add cockpit to the IoT image so you can access the board from a web browser.
https://<ip or host name of your board>:/9090
Accept the certificate miss match and go on in to your board.
As far as VS code, much better options exist. Running either CLion or Pycharm you can do remote builds on your board over ethernet. Not sure if the free version will let you run remote, you might have to get the paid version. If you are a student they have programs for that and those that help out with open source.
I tried https://192.168.7.2:/9090, https://192.168.7.2:9090 and I cannot connect.
Only 192.168.7.2 works (cloud9 ide).
@miszka using 9090/cockpit, requires installing cockpit…
If you have cloud9 running, there is a good chance that image pre-dates cockpit availability.
Post a link to the exact image you are running.
It is Debian I get preinstalled on eMMC.
Operating System: Debian GNU/Linux 10 (buster)
Kernel: Linux 4.19.94-ti-r42
Issue 2.3 has been solved.
I had made Internet connection, and installed gdb and gdb server. Now I can run blinkLED example. Thank you.
Status of issues:
Issue 2.3 - gdbserver not available. problem solved
