BeagleBone Black industrial image flashing failure
Hey,
I’ve succesfully used beaglebone black industrials in the past, where I could easily flash a new image on the beaglebone. But now I’m having issues with it. I tried it with an micro sd card with my default image on it. Just pop it in and powerup the beaglebone. This didn’t work nothing seemed to happen. The next step was to start up the beaglebone without the sd card inside. The beaglebone booted up without any issues. So I eddited the uEnv.txt as described on the official website. This still didn’t work and even worse now the beagleBone didn’t seem to start anymore. So the next step was dig up a serial converter and use the serial port. No with the serial debugger on I can see that the install porccess seems to hang:
What can I do? I have tried multiple images on the SD card, also the images provided by the official website.
Smells like 2 bugs (you didn’t post the 2nd picture (which is in your google groups post))…
Please post the full boot log with your “microSD” inserted (Putty allows saving log to a file…)
U-Boot SPL 2019.04-00002-g31a8ae0206 (May 13 2020 - 09:26:17 -0500)
Trying to boot from MMC2
Loading Environment from EXT4...
** Unable to use mmc 0:1 for loading the env **
U-Boot 2019.04-00002-g31a8ae0206 (May 13 2020 - 09:26:17 -0500), Build: jenkins-github_Bootloader-Builder-139
CPU  : AM335X-GP rev 2.1
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
Reset Source: Global external warm reset has occurred.
RTC 32KCLK Source: External.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBone Black Industrial:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net:   eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[EIA0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2904 bytes read in 37 ms (76.2 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-3.8.13-bone79 ...
5644336 bytes read in 402 ms (13.4 MiB/s)
debug: [enable_uboot_overlays=] ...
loading /boot/dtbs/3.8.13-bone79/am335x-boneblack.dtb ...
26118 bytes read in 52 ms (490.2 KiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
loading /boot/initrd.img-3.8.13-bone79 ...
2985136 bytes read in 232 ms (12.3 MiB/s)
debug: [console=ttyO0,115200n8 root=UUID=90ddd1c8-f67f-4dc9-8b88-00005bff6dff ro rootfstype=ext4 rootwait init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh] ...
debug: [bootz 0x82000000 0x88080000:2d8cb0 0x88000000] ...
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8fd27000, end 8ffffcb0 ... OK
   Loading Device Tree to 8fd1d000, end 8fd26605 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.8.13-bone79 (root@a4-imx6q-wandboard-2gb) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Tue Oct 13 20:44:55 UTC 2015
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (l2cache sgx neon )
[    0.000000] PERCPU: Embedded 9 pages/cpu @c0d5e000 s14080 r8192 d14592 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129792
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=UUID=90ddd1c8-f67f-4dc9-8b88-00005bff6dff ro rootfstype=ext4 rootwait init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] __ex_table already sorted, skipping sort
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 511MB = 511MB total
[    0.000000] Memory: 505168k/505168k available, 19120k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
[    0.000000]       .text : 0xc0008000 - 0xc080cef8   (8212 kB)
[    0.000000]       .init : 0xc080d000 - 0xc084a700   ( 246 kB)
[    0.000000]       .data : 0xc084c000 - 0xc08d4180   ( 545 kB)
[    0.000000]        .bss : 0xc08d4180 - 0xc094d940   ( 486 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] NR_IRQS:0 nr_irqs:0 0
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000237] Calibrating delay loop... 993.47 BogoMIPS (lpj=969728)
[    0.029188] pid_max: default: 32768 minimum: 301
[    0.029324] Security Framework initialized
[    0.029381] Mount-cache hash table entries: 512
[    0.035136] Initializing cgroup subsys cpuacct
[    0.035160] Initializing cgroup subsys memory
[    0.035198] Initializing cgroup subsys blkio
[    0.035285] CPU: Testing write buffer coherency: ok
[    0.035662] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.035714] Setting up static identity map for 0x804da4c8 - 0x804da514
[    0.036634] Brought up 1 CPUs
[    0.036647] SMP: Total of 1 processors activated (993.47 BogoMIPS).
[    0.037432] devtmpfs: initialized
[    0.045734] omap_hwmod: wd_timer2: _wait_target_disable failed
[    0.085483] pinctrl core: initialized pinctrl subsystem
[    0.085618] rstctl core: initialized rstctl subsystem
[    0.085949] regulator-dummy: no parameters
[    0.086268] NET: Registered protocol family 16
[    0.086780] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.092333] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.092891] platform 49000000.edma: alias fck already exists
[    0.092909] platform 49000000.edma: alias fck already exists
[    0.092922] platform 49000000.edma: alias fck already exists
[    0.093608] OMAP GPIO hardware version 0.1
[    0.096145] gpio-rctrl rstctl.4: loaded OK
[    0.099415] No ATAGs?
[    0.099432] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.100702] cpsw.0: No hwaddr in dt. Using 14:42:fc:e8:85:15 from efuse
[    0.100721] cpsw.1: No hwaddr in dt. Using 14:42:fc:e8:85:17 from efuse
[    0.108933] bio: create slab <bio-0> at 0
[    0.115233] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.115507] vmmcsd_fixed: 3300 mV
[    0.117105] SCSI subsystem initialized
[    0.117348] usbcore: registered new interface driver usbfs
[    0.117421] usbcore: registered new interface driver hub
[    0.117608] usbcore: registered new device driver usb
[    0.118789] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    0.119760] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[    0.120946] DCDC1: at 1500 mV
[    0.121801] vdd_mpu: 925 <--> 1325 mV at 1325 mV
[    0.122606] vdd_core: 925 <--> 1150 mV at 1100 mV
[    0.123409] LDO1: at 1800 mV
[    0.124192] LDO2: at 3300 mV
[    0.125710] LDO3: 1800 mV
[    0.126514] LDO4: at 3300 mV
[    0.127273] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    0.127732] omap_i2c 44e0b000.i2c: unable to select pin group
[    0.128179] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[    0.129612] omap_i2c 4819c000.i2c: unable to select pin group
[    0.129753] media: Linux media interface: v0.10
[    0.129816] Linux video capture interface: v2.00
[    0.129884] pps_core: LinuxPPS API ver. 1 registered
[    0.129893] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.129916] PTP clock support registered
[    0.130310] Advanced Linux Sound Architecture Driver Initialized.
[    0.130982] NetLabel: Initializing
[    0.130993] NetLabel:  domain hash size = 128
[    0.130999] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.131065] NetLabel:  unlabeled traffic allowed by default
[    0.131232] Switching to clocksource gp_timer
[    0.162701] NET: Registered protocol family 2
[    0.163332] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.163412] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[    0.163493] TCP: Hash tables configured (established 4096 bind 4096)
[    0.163554] TCP: reno registered
[    0.163568] UDP hash table entries: 256 (order: 1, 12288 bytes)
[    0.163591] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[    0.163820] NET: Registered protocol family 1
[    0.164214] RPC: Registered named UNIX socket transport module.
[    0.164227] RPC: Registered udp transport module.
[    0.164234] RPC: Registered tcp transport module.
[    0.164241] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.164463] Trying to unpack rootfs image as initramfs...
[    0.376149] Freeing initrd memory: 2912K
[    0.376450] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[    0.376711] CPU PMU: attempt to register multiple PMU devices!
[    0.376733] arm-pmu: probe of arm-pmu failed with error -28
[    0.377035] omap2_mbox_probe: platform not supported
[    0.528122] VFS: Disk quotas dquot_6.5.2
[    0.528260] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.528968] NFS: Registering the id_resolver key type
[    0.529038] Key type id_resolver registered
[    0.529046] Key type id_legacy registered
[    0.529317] fuse init (API version 7.20)
[    0.529778] Btrfs loaded
[    0.529893] msgmni has been set to 992
[    0.531489] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.531506] io scheduler noop registered
[    0.531514] io scheduler deadline registered
[    0.531535] io scheduler cfq registered (default)
[    0.532727] tps65217-bl tps65217-bl: no platform data provided
[    0.532752] tps65217-bl: probe of tps65217-bl failed with error -22
[    0.533267] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.534620] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[    0.534888] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    1.294605] console [ttyO0] enabled
[    1.298901] [drm] Initialized drm 1.1.0 20060810
[    1.311008] brd: module loaded
[    1.317915] loop: module loaded
[    1.321304] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.328565] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.335780] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.342997] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.350221] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.364123] bone-capemgr bone_capemgr.9: Baseboard: 'A335BNLT,EIA0,2037SBI07902'
[    1.371872] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-black
[    1.410599] bone-capemgr bone_capemgr.9: slot #0: No cape found
[    1.447706] bone-capemgr bone_capemgr.9: slot #1: No cape found
[    1.484815] bone-capemgr bone_capemgr.9: slot #2: No cape found
[    1.521924] bone-capemgr bone_capemgr.9: slot #3: No cape found
[    1.528153] bone-capemgr bone_capemgr.9: slot #4: specific override
[    1.534733] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[    1.542729] bone-capemgr bone_capemgr.9: slot #4: 'Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G'
[    1.552790] bone-capemgr bone_capemgr.9: slot #5: specific override
[    1.559343] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[    1.567354] bone-capemgr bone_capemgr.9: slot #5: 'Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI'
[    1.577337] bone-capemgr bone_capemgr.9: slot #6: specific override
[    1.583900] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[    1.591901] bone-capemgr bone_capemgr.9: slot #6: 'Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN'
[    1.602301] bone-capemgr bone_capemgr.9: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[    1.611126] bone-capemgr bone_capemgr.9: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[    1.619923] bone-capemgr bone_capemgr.9: loader: before slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[    1.628670] bone-capemgr bone_capemgr.9: loader: check slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[    1.637335] bone-capemgr bone_capemgr.9: initialized OK.
[    1.642894] bone-capemgr bone_capemgr.9: loader: before slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.651715] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.661891] OneNAND driver initializing
[    1.666812] usbcore: registered new interface driver cdc_ether
[    1.672943] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[    1.681730] usbcore: registered new interface driver rndis_host
[    1.687981] bone-capemgr bone_capemgr.9: loader: after slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[    1.696639] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.705429] usbcore: registered new interface driver cdc_ncm
[    1.711378] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware 'cape-bone-2g-emmc1.dtbo' for board-name 'Bone-LT-eMMC-2G', version '00A0'
[    1.725405] usbcore: registered new interface driver cdc_acm
[    1.731334] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.739693] Initializing USB Mass Storage driver...
[    1.744810] bone-capemgr bone_capemgr.9: slot #4: dtbo 'cape-bone-2g-emmc1.dtbo' loaded; converting to live tree
[    1.755497] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware 'cape-boneblack-hdmi-00A0.dtbo' for board-name 'Bone-Black-HDMI', version '00A0'
[    1.769647] usbcore: registered new interface driver usb-storage
[    1.775935] USB Mass Storage support registered.
[    1.780957] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[    1.787575] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[    1.794419] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[    1.803093] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.811862] bone-capemgr bone_capemgr.9: slot #5: dtbo 'cape-boneblack-hdmi-00A0.dtbo' loaded; converting to live tree
[    1.823201] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    1.829748] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[    1.834965] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:480 dsps_musb_init: OK
[    1.844273] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[    1.851646] platform 4830e000.fb: alias fck already exists
[    1.857651] musb-hdrc musb-hdrc.0.auto: *** mode=3
[    1.862690] musb-hdrc musb-hdrc.0.auto: *** power=250
[    1.868899] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[    1.875783] bone-capemgr bone_capemgr.9: loader: done slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[    1.884371] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.893555] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[    1.898785] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:480 dsps_musb_init: OK
[    1.907549] bone-capemgr bone_capemgr.9: loader: after slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    1.916420] musb-hdrc musb-hdrc.1.auto: *** mode=1
[    1.921447] musb-hdrc musb-hdrc.1.auto: *** power=250
[    1.926730] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.932757] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware 'cape-boneblack-hdmin-00A0.dtbo' for board-name 'Bone-Black-HDMIN', version '00A0'
[    1.947114] bone-capemgr bone_capemgr.9: slot #6: dtbo 'cape-boneblack-hdmin-00A0.dtbo' loaded; converting to live tree
[    1.958652] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.967007] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.974135] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.981705] usb usb1: Product: MUSB HDRC host driver
[    1.986898] usb usb1: Manufacturer: Linux 3.8.13-bone79 musb-hcd
[    1.993180] usb usb1: SerialNumber: musb-hdrc.1.auto
[    1.998617] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[    2.008204] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[    2.014947] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[    2.025426] hub 1-0:1.0: USB hub found
[    2.029438] hub 1-0:1.0: 1 port detected
[    2.034366] mousedev: PS/2 mouse device common for all mice
[    2.041220] lsm303dlhc_acc accelerometer driver: init
[    2.046637] i2c-core: driver [lsm303dlhc_acc] using legacy suspend method
[    2.053754] i2c-core: driver [lsm303dlhc_acc] using legacy resume method
[    2.060766] lsm303dlhc_mag driver: init
[    2.064821] lsm330_acc accelerometer driver: init
[    2.069791] i2c-core: driver [lsm330_acc] using legacy suspend method
[    2.076526] i2c-core: driver [lsm330_acc] using legacy resume method
[    2.083163] lsm330_gyr: gyroscope sysfs driver init
[    2.088842] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    2.096261] 44e3e000.rtc: already running
[    2.100623] i2c /dev entries driver
[    2.105239] pps_ldisc: PPS line discipline registered
[    2.110627] Driver for 1-wire Dallas network protocol.
[    2.117127] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    2.124753] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-devel@redhat.com
[    2.133650] cpuidle: using governor ladder
[    2.138205] cpuidle: using governor menu
[    2.142618] omap_hsmmc mmc.5: of_parse_phandle_with_args of 'reset' failed
[    2.149826] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[    2.156488] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[    2.163643] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[    2.170885] mmc.5 supply vmmc_aux not found, using dummy regulator
[    2.177694] omap_hsmmc mmc.5: pins are not configured from the driver
[    2.211595] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[    2.217983] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[    2.225957] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[    2.232346] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[    2.239435] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[    2.246797] mmc.11 supply vmmc_aux not found, using dummy regulator
[    2.253445] omap_hsmmc mmc.11: pins are not configured from the driver
[    2.287885] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[    2.299565] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[    2.306843] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[    2.315783] leds-gpio gpio-leds.8: pins are not configured from the driver
[    2.323884] ledtrig-cpu: registered to indicate activity on CPUs
[    2.330485] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[    2.337681] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    2.345152] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    2.351355] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[    2.358492] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[    2.367492] mmc0: host does not support reading read-only switch. assuming write-enable.
[    2.376938] usbcore: registered new interface driver usbhid
[    2.382812] usbhid: USB HID core driver
[    2.387776] ashmem: initialized
[    2.391223] mmc0: new high speed SDHC card at address 59b4
[    2.397219] logger: created 256K log 'log_main'
[    2.402444] mmcblk0: mmc0:59b4       29.6 GiB
[    2.407357] logger: created 256K log 'log_events'
[    2.413093] logger: created 256K log 'log_radio'
[    2.418074]  mmcblk0: p1 p2
[    2.421443] logger: created 256K log 'log_system'
[    2.428284] usb 1-1: new full-speed USB device number 2 using musb-hdrc
[    2.436854] davinci_evm sound.14:  nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[    2.446549] TCP: cubic registered
[    2.450151] NET: Registered protocol family 10
[    2.455759] NET: Registered protocol family 17
[    2.460706] Key type dns_resolver registered
[    2.465400] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    2.473513] ThumbEE CPU extension supported.
[    2.478020] Registering SWP/SWPB emulation handler
[    2.483718] registered taskstats version 1
[    2.489627] tilcdc 4830e000.fb: No power control GPIO
[    2.529976] mmc1: unrecognised EXT_CSD revision 8
[    2.534942] mmc1: error -22 whilst initialising MMC card
[    2.568272] usb 1-1: New USB device found, idVendor=0403, idProduct=6001
[    2.575293] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.582769] usb 1-1: Product: USB-RS485 Cable
[    2.587320] usb 1-1: Manufacturer: FTDI
[    2.591342] usb 1-1: SerialNumber: FT4NQFVE
[    2.610337] tilcdc 4830e000.fb: found TDA19988
[    2.615574] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    2.622503] [drm] No driver support for vblank timestamp query.
[    2.628962] tilcdc 4830e000.fb: No connectors reported connected with modes
[    2.636264] [drm] Cannot find any crtc or sizes - going 1024x768
[    2.651873] Console: switching to colour frame buffer device 128x48
[    2.664491] tilcdc 4830e000.fb: fb0:  frame buffer device
[    2.670143] tilcdc 4830e000.fb: registered panic notifier
[    2.675805] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[    2.730932] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    2.737322] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[    2.750681] libphy: 4a101000.mdio: probed
[    2.754930] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    2.764695] Detected MACID = 14:42:fc:e8:85:15
[    2.769310] cpsw 4a100000.ethernet: NAPI disabled
[    2.776002] omap_rtc 44e3e000.rtc: setting system clock to 2015-11-12 19:47:06 UTC (1447357626)
[    2.789832] ALSA device list:
[    2.792991]   #0: TI BeagleBone Black
[    2.797476] Freeing init memory: 244K
Loading, please wait...
[    2.872112] udevd[97]: starting version 175
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... done.
[    4.064291] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Begin: Running /scripts/local-bottom ... done.
done.
Begin: Running /scripts/init-bottom ... done.
Starting eMMC Flasher from microSD media
Version: [1.20151007: gpt partitions with raw boot...]
Checking for Valid bbb-eeprom header
Valid bbb-eeprom header found [335]
copying: [/dev/mmcblk0] -> [/dev/mmcblk1]
lsblk:
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
mmcblk0     179:0    0  29.7G  0 disk
|-mmcblk0p1 179:1    0    96M  0 part /boot/uboot
`-mmcblk0p2 179:2    0  29.6G  0 part /
df -h | grep rootfs:
rootfs                                                   30G  2.1G   26G   8% /
Error: [/dev/mmcblk1] does not exist
writing to [/dev/mmcblk1] failed...
[   10.027928] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[   10.027928]
[   10.037506] [<c00114f1>] (unwind_backtrace+0x1/0x9c) from [<c04d0add>] (panic+0x59/0x15c)
[   10.046051] [<c04d0add>] (panic+0x59/0x15c) from [<c0033a8f>] (do_exit+0x5ff/0x68c)
[   10.054044] [<c0033a8f>] (do_exit+0x5ff/0x68c) from [<c0033b5f>] (do_group_exit+0x27/0x6c)
[   10.062674] [<c0033b5f>] (do_group_exit+0x27/0x6c) from [<c0033baf>] (sys_exit_group+0xb/0xc)
[   10.071569] [<c0033baf>] (sys_exit_group+0xb/0xc) from [<c000c841>] (ret_fast_syscall+0x1/0x46)
[   10.080655] drm_kms_helper: panic occurred, switching back to text console
I realized that if I added the uEnv.txt on the sd-card image to comment the init script again I can load the image on the sd-card.
Below I have the log when trying to use the flasher image from the sd-card to update the eMMC.
I have the log at: https://we.tl/t-b0WujS4Shh
The forum complains when I insert the text, it says I can only post with a max of two links in my message.
I fixed this 5 years ago:
The Kernel on your microSD is too old to support new versions of the eMMC… Feel free to upgrade at any time…
When booting without sd-card.
Thank you very much Robert,
I taught I had tried the latest flasher image from the Beaglebone website itself, but somehow I was mistaken or something else went wrong. I have just flashed the latest image and it went without any issues.
Kind regards,
Ruben
I had one last question which is a bit unrelated. Do you know a quick solution to have a custom webpage load on entering the IP address in the webpage. Because now it automatically loads Cloud9. I still want cloud9 to run and with the password protection, but have the IP address without the port number redirect to a custom webpage.
By default nginx is configured to proxy_pass / to cloud9 (port 3000)
	location / {
		#Cloud9
		proxy_pass http://localhost:3000;
Feel free to change it.
