I’m used the install Ubuntu 13.10 OS on the two Beaglebone Black. (Testing the small web server)
However, when the reboot will not boot. ( Input the “shutdown -r now” command after connected the ssh. )
One device is a all LED is on always, not boot and connect. (Rev A5C)
The other device is a first LED is Blink always, but not boot and connect. (Rev B)
Apache, php, mysql other than software has not installed.
Please advice about how to solve this problem.
Can you connect a serial cable and capture the console logs?
I can not connect to the console.
LED is operated, but BBB is does not connect.
2016년 7월 12일 화요일 오후 5시 41분 26초 UTC+9, Jason Kridner 님의 말:
See:
http://elinux.org/Beagleboard:BeagleBone_Black_Accessories#Serial_Debug_Cables
The serial cable plugs directly into the Beaglebone, and is used to debug problems with the unit.
— Graham
Thank you for reply.
I was tried connect to debug mode used serial cable.
but, is not connect. It has been shown a lot of broken character on the screen.
(setting = Baud 115,200 / Bits 8 / Parity N / Stop Bits 1 / Handshake None )
I will browse the another method.
2016년 7월 13일 수요일 오전 10시 4분 37초 UTC+9, Graham 님의 말:
Make sure all flow control is of. I’ve purchased some cables where TX and RX are reversed, check that well
