Hello, I have done a git clone on https://github.com/korevec/node-i2c. Now I want to use those in the cloud9 IDE. But when I typed
var i2c = require(‘i2c’);
node has very specific path requirements that you should read about
elsewhere. If you put it at the path 'node_modules/i2c' relative to your
script, it should work. You could also use 'npm' to install it, even
globally using 'npm install -g i2c'.
I'm in the process of integrating node-i2c into bonescript and should
release it "any day now"(TM).
