Hi All,
I needed to modify my MLO and U-boot.img files in order to 1) chage DDR settings (I am using a different DDR chip than the stock BB chip), and also to configure autoboot settings.
I cloned u-boot, changed the settings I needed to change, compiled U-Boot and copied MLO and U-Boot.img to the correct partition on my bootable MMC card.
The BB boots fine from the SD card, with auto-boot configured as I want it to be, and also the RAM settings are fine.
However, when I try to clone my image onto the MMC, boot hangs up with the error shown in the subject line.
If I clone my image from the SD card to the MMC without my modified U-Boot, the Beagle Bone works fine. SO, in summary:
my modified u-boot files work fine when booting from SD card.
I can clone my SD card to the MMC of the BB an it works fine, using DD from an image file.
I can not clone my SD card to the MMC with the modified u-boot files… it will not boot in that circumstance.
I have tried running the script located at https://github.com/RobertCNelson/tools/tree/master/scripts to copy the SD card to the MMC (errors out with not enough space on device when copying). I have also tried loading the files through tftpboot, and still get the same error. I suspect that I have to change some setting in U-boot which has to do with load addresses, but not sure where/how to do this.
Any help would be apprectiated! My boot messages are below:
U-Boot SPL 2015.10-rc3-00297-g1a9c229-dirty (Sep 25 2015 - 18:11:28)
*** Warning - bad CRC, using default environment
reading u-boot.img
reading u-boot.img
U-Boot 2015.10-rc3-00297-g1a9c229-dirty (Sep 25 2015 - 18:11:28 -0600)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
cpsw, usb_ether
Card did not respond to voltage select!
switch to partitions #0, OK
SD/MMC found on device 1
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
716 bytes read in 5 ms (139.6 KiB/s)
Running uenvcmd …
3341744 bytes read in 237 ms (13.4 MiB/s)
** Bad device mmc 0 **
24884 bytes read in 41 ms (591.8 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x32fdb0 ]
Loading Device Tree to 8fff6000, end 8ffff133 … OK
Starting kernel …
[ 0.189961] omap2_mbox_probe: platform not supported
[ 0.346539] tps65217-bl tps65217-bl: no platform data provided
[ 0.410880] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.447987] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.485094] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.522203] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.542272] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.551911] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.558686] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.574192] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 0.638029] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.649803] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.657120] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 0.682772] dummy 0-0034: Error -121 writing to cec:0xff
[ 0.688534] tda998x 0-0070: Error -121 reading from 0xa
[ 0.694183] tda998x 0-0070: Error -121 writing to 0xa //HDMI CHIP IS REMOVED,
[ 0.750834] tda998x 0-0070: Error -121 reading from 0xa
[ 0.756434] tda998x 0-0070: Error -121 writing to 0xa
[ 0.813284] tda998x 0-0070: Error -121 reading from 0x1
[ 0.818856] tda998x 0-0070: Error -121 writing to 0x1
[ 0.824241] tda998x 0-0070: Error -121 reading from 0x1
[ 0.829808] tda998x 0-0070: Error -121 writing to 0x1
[ 0.835192] tda998x 0-0070: Error -121 writing to REG_CURPAGE
[ 0.841300] tda998x 0-0070: Error -121 writing to 0x200
[ 0.846867] tda998x 0-0070: Error -121 writing to 0x201
[ 0.852508] tda998x 0-0070: Error -121 writing to 0x202
[ 0.858079] tda998x 0-0070: Error -121 writing to 0x203
[ 0.863648] tda998x 0-0070: Error -121 writing to 0x204
[ 0.869213] tda998x 0-0070: Error -121 writing to 0x205
[ 0.874776] tda998x 0-0070: Error -121 writing to 0x20e
[ 0.880337] tda998x 0-0070: Error -121 writing to 0x211
[ 0.885900] tda998x 0-0070: Error -121 writing to 0x207
[ 0.891461] tda998x 0-0070: Error -121 writing to 0x208
[ 0.897023] tda998x 0-0070: Error -121 writing to 0x209
[ 0.902586] tda998x 0-0070: Error -121 writing to 0x20a
[ 0.908149] tda998x 0-0070: Error -121 writing to 0x206
[ 0.913708] tda998x 0-0070: Error -121 writing to REG_CURPAGE
[ 0.919816] tda998x 0-0070: Error -121 reading from 0x0
[ 0.925379] tda998x 0-0070: Error -121 reading from 0x2
[ 0.931109] tilcdc 4830e000.fb: no encoders/connectors found
[ 0.937069] tilcdc 4830e000.fb: failed to initialize mode setting
[ 1.001020] VFS: PARTUUID= is invalid.
[ 1.001020] Expected PARTUUID=[/PARTNROFF=%d]
[ 1.010925] Disabling rootwait; root= is invalid.
[ 1.016456] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.025163] [] (unwind_backtrace+0x0/0xe0) from [] (panic+0x84/0x1e0)
[ 1.033749] [] (panic+0x84/0x1e0) from [] (mount_block_root+0x1e4/0x224)
[ 1.042595] [] (mount_block_root+0x1e4/0x224) from [] (mount_root+0xe8/0x108)
[ 1.051895] [] (mount_root+0xe8/0x108) from [] (prepare_namespace+0x15c/0x1bc)
[ 1.061285] [] (prepare_namespace+0x15c/0x1bc) from [] (kernel_init+0x8/0xe4)
[ 1.070589] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c)
