I have a Beaglebone-black rev C, but my operating system is Windows 11 and I can’t get it to work, do you know of anything how to do it? I can access the folders, but it tells me that the RNDIS driver is not recognized
Hello…
use wsl2.
I use WSL2 to ssh into the board…
What version of the os are you using, I’ve tested windows 11 recently and the ncm interface worked out of the box. (No drivers install required)
windows 11 professional
Sorry the firmware version on the BBB?
I already logged in via ssh
Oh. Okay, so you can ssh into the BBB but need drivers for some reason. I am sorry. I misunderstood.
P.S. I am not sure about the drivers any longer as the BBB on my side of things can connect directly to the host via ssh, sftp, and by way of getting online via Ethernet. I am not sure as of now why drivers for a Win 11 desktop will be needed at all since you can already use your BBB via ssh and “Ethernet.” Please let me know if I am off base here.
Windows 11 has added the out of box ability to just use usb NCM interfaces just like Mac (and Linux) without random driver installs… So no worrying about setting the perfect RNDIS usb configuration on the BeagleBone Black… Standard NCM just works now…
Dealing with drivers can be frustrating, especially with newer OS versions like Windows 11. When I had issues with drivers not being recognized after upgrading, I found that manually updating them through Device Manager helped. For your BeagleBone Black Rev C, specifically the RNDIS driver, try downloading the latest driver from the manufacturer’s website if it’s not automatically recognized. By the way, if you’re considering upgrading to Windows 11 Pro, I got my key from Digital Chill Mart and had a smooth experience.
getting BeagleBone Black Rev C working on Windows 11 can be tricky! Make sure you’ve got the latest drivers installed and check if USB debugging is enabled. If issues continue, upgrading to a Windows 11 Pro setup might offer better support for dev boards. Good luck!
