I have been following this USB thread for a while and wanted to add my 2 cents. I have a related but “opposite” problem. My hot plug works but my cold plugs does not. Let me clarify.
What works:
- Boot the Beagle Bone Black (the “BBB”) with now USB pluged in
- Plug in a powered USB hub
- Everything works as expected
- Unplug usb
- Plug USB back in. Everything works as expected. So hot plug works.
What fails
- Power up the BBB with the powered USB connected. The USB hub come up alot faster than the BBB.
- No matter what is done, there is no way to get the BBB to see the USB devices apart from following up a reboot / power cycle as stated above.
Comments:
OS: Richard Nelson’s Linux version 3.8.13-bone30 (root@imx6q-sabrelite-1gb-1) (gcc version
4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu8) ) #1 SMP Thu Nov 14 06:23:24 UTC 2013
Hardware: BBB Rev B. Only started shipping from March 2014 onwards. I noticed a capacitor discrete mounted near the USB port. Is this a Rev B hack?
What I am trying to solve
I would like to have the USB devices come online upon power up without having to observe the (1) BBB on first (2) plug in the USB Hub + devices sequence. I.E. if I stick all this stuff into an embedded gadget it would not come up on power up. I would have to have some sort of two-phase relay hardware in place to (1) power up the BBB first, then (2) the USB + USB devices / dongles.
Any thoughts / solutions?
Best, Mike
Some cut-and-paste info
buntu@woofieone:~$ lsusb
Bus 001 Device 007: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 006: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 008: ID 154b:004f PNY
Bus 001 Device 005: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Here is a USB GREP
ubuntu@woofieone:~$ dmesg | egrep usb
[ 0.135150] usbcore: registered new interface driver usbfs
[ 0.135217] usbcore: registered new interface driver hub
[ 0.135457] usbcore: registered new device driver usb
[ 1.464285] usbcore: registered new interface driver cdc_ether
[ 1.479302] usbcore: registered new interface driver rndis_host
[ 1.503131] usbcore: registered new interface driver cdc_ncm
[ 1.523280] usbcore: registered new interface driver cdc_acm
[ 1.567758] usbcore: registered new interface driver usb-storage
[ 1.621644] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.628255] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.633507] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.656309] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.656326] musb-hdrc: MHDRC RTL version 2.0
[ 1.656335] musb-hdrc: setup fifo_mode 4
[ 1.656351] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.656456] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.661525] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.692769] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.698031] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.715656] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.715668] musb-hdrc: MHDRC RTL version 2.0
[ 1.715677] musb-hdrc: setup fifo_mode 4
[ 1.715689] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.715786] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.720837] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.726151] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.758390] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.766666] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[ 1.766748] usb usb1: default language 0x0409
[ 1.766783] usb usb1: udev 1, busnum 1, minor = 0
[ 1.766796] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.773951] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.781539] usb usb1: Product: MUSB HDRC host driver
[ 1.786761] usb usb1: Manufacturer: Linux 3.8.13-bone30 musb-hcd
[ 1.793073] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.825146] usb usb1: usb_probe_device
[ 1.825166] usb usb1: configuration #1 chosen from 1 choice
[ 1.825217] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 1.825330] hub 1-0:1.0: usb_probe_interface
[ 1.825343] hub 1-0:1.0: usb_probe_interface - got id
[ 1.934524] usb usb1: bus auto-suspend, wakeup 1
[ 2.116993] usbcore: registered new interface driver usbhid
[ 2.122933] usbhid: USB HID core driver
[ 5.561628] usbcore: registered new interface driver rtl8192cu
[ 23.760104] usb usb1: usb wakeup-resume
[ 23.760150] usb usb1: usb auto-resume
[ 23.969260] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 24.088645] usb 1-1: default language 0x0409
[ 24.088715] usb 1-1: udev 2, busnum 1, minor = 1
[ 24.088730] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 24.088742] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 24.088753] usb 1-1: Product: USB 2.0 Hub
[ 24.090507] usb 1-1: usb_probe_device
[ 24.090535] usb 1-1: configuration #1 chosen from 1 choice
[ 24.092498] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[ 24.092724] hub 1-1:1.0: usb_probe_interface
[ 24.092741] hub 1-1:1.0: usb_probe_interface - got id
[ 24.363806] usb 1-1.3: new full-speed USB device number 3 using musb-hdrc
[ 24.459263] usb 1-1.3: default language 0x0409
[ 24.461214] usb 1-1.3: udev 3, busnum 1, minor = 2
[ 24.461232] usb 1-1.3: New USB device found, idVendor=0a12, idProduct=0001
[ 24.461245] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 24.461256] usb 1-1.3: Product: CSR8510 A10
[ 24.461819] usb 1-1.3: usb_probe_device
[ 24.461839] usb 1-1.3: configuration #1 chosen from 1 choice
[ 24.462756] usb 1-1.3: adding 1-1.3:1.0 (config #1, interface 0)
[ 24.463213] usb 1-1.3: adding 1-1.3:1.1 (config #1, interface 1)
[ 24.519918] btusb 1-1.3:1.0: usb_probe_interface
[ 24.519949] btusb 1-1.3:1.0: usb_probe_interface - got id
[ 24.529170] usbcore: registered new interface driver btusb
[ 24.533029] usb 1-1.4: new high-speed USB device number 4 using musb-hdrc
[ 24.612124] usb 1-1.4: default language 0x0409
[ 24.612211] usb 1-1.4: udev 4, busnum 1, minor = 3
[ 24.612227] usb 1-1.4: New USB device found, idVendor=1a40, idProduct=0101
[ 24.612240] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 24.612251] usb 1-1.4: Product: USB 2.0 Hub
[ 24.612741] usb 1-1.4: usb_probe_device
[ 24.612762] usb 1-1.4: configuration #1 chosen from 1 choice
[ 24.612904] usb 1-1.4: adding 1-1.4:1.0 (config #1, interface 0)
[ 24.613060] hub 1-1.4:1.0: usb_probe_interface
[ 24.613074] hub 1-1.4:1.0: usb_probe_interface - got id
[ 24.717887] usb 1-1.4: usb auto-suspend, wakeup 1
[ 58.956081] usb 1-1: USB disconnect, device number 2
[ 58.956095] usb 1-1.3: USB disconnect, device number 3
[ 58.956106] usb 1-1.3: unregistering device
[ 58.956119] usb 1-1.3: unregistering interface 1-1.3:1.0
[ 58.956467] musb-hdrc musb-hdrc.1.auto: shutdown urb de1c4bc0 ep1in-intr
[ 58.956491] musb-hdrc musb-hdrc.1.auto: shutdown urb de329f40 ep2in-bulk
[ 58.956508] musb-hdrc musb-hdrc.1.auto: shutdown urb de329e40 ep2in-bulk
[ 58.966138] usb 1-1.3: unregistering interface 1-1.3:1.1
[ 58.966430] usb 1-1.3: usb_disable_device nuking all URBs
[ 58.966915] usb 1-1.4: USB disconnect, device number 4
[ 58.966930] usb 1-1.4: unregistering device
[ 58.966942] usb 1-1.4: unregistering interface 1-1.4:1.0
[ 58.967341] usb 1-1.4: usb_disable_device nuking all URBs
[ 58.969200] usb 1-1: unregistering device
[ 58.969222] usb 1-1: unregistering interface 1-1:1.0
[ 58.969414] musb-hdrc musb-hdrc.1.auto: shutdown urb de1c46c0 ep1in-intr
[ 58.973932] usb 1-1: usb_disable_device nuking all URBs
[ 59.083145] usb usb1: bus auto-suspend, wakeup 1
[ 67.196410] usb usb1: usb wakeup-resume
[ 67.196457] usb usb1: usb auto-resume
[ 67.405253] usb 1-1: new high-speed USB device number 5 using musb-hdrc
[ 67.524620] usb 1-1: default language 0x0409
[ 67.524688] usb 1-1: udev 5, busnum 1, minor = 4
[ 67.524702] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 67.524715] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 67.524726] usb 1-1: Product: USB 2.0 Hub
[ 67.526497] usb 1-1: usb_probe_device
[ 67.526525] usb 1-1: configuration #1 chosen from 1 choice
[ 67.528467] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[ 67.528691] hub 1-1:1.0: usb_probe_interface
[ 67.528708] hub 1-1:1.0: usb_probe_interface - got id
[ 67.799792] usb 1-1.3: new full-speed USB device number 6 using musb-hdrc
[ 67.895269] usb 1-1.3: default language 0x0409
[ 67.897204] usb 1-1.3: udev 6, busnum 1, minor = 5
[ 67.897222] usb 1-1.3: New USB device found, idVendor=0a12, idProduct=0001
[ 67.897235] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 67.897246] usb 1-1.3: Product: CSR8510 A10
[ 67.897799] usb 1-1.3: usb_probe_device
[ 67.897820] usb 1-1.3: configuration #1 chosen from 1 choice
[ 67.898711] usb 1-1.3: adding 1-1.3:1.0 (config #1, interface 0)
[ 67.898948] btusb 1-1.3:1.0: usb_probe_interface
[ 67.898965] btusb 1-1.3:1.0: usb_probe_interface - got id
[ 67.902207] usb 1-1.3: adding 1-1.3:1.1 (config #1, interface 1)
[ 67.969786] usb 1-1.4: new high-speed USB device number 7 using musb-hdrc
[ 68.050043] usb 1-1.4: default language 0x0409
[ 68.050111] usb 1-1.4: udev 7, busnum 1, minor = 6
[ 68.050125] usb 1-1.4: New USB device found, idVendor=1a40, idProduct=0101
[ 68.050138] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 68.050149] usb 1-1.4: Product: USB 2.0 Hub
[ 68.050658] usb 1-1.4: usb_probe_device
[ 68.050679] usb 1-1.4: configuration #1 chosen from 1 choice
[ 68.050816] usb 1-1.4: adding 1-1.4:1.0 (config #1, interface 0)
[ 68.050956] hub 1-1.4:1.0: usb_probe_interface
[ 68.050970] hub 1-1.4:1.0: usb_probe_interface - got id
[ 68.155761] usb 1-1.4: usb auto-suspend, wakeup 1
[ 280.645675] usb 1-1.1: new high-speed USB device number 8 using musb-hdrc
[ 280.857913] usb 1-1.1: default language 0x0409
[ 280.859216] usb 1-1.1: udev 8, busnum 1, minor = 7
[ 280.859265] usb 1-1.1: New USB device found, idVendor=154b, idProduct=004f
[ 280.859305] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 280.859340] usb 1-1.1: Product: USB 2.0 FD
[ 280.859373] usb 1-1.1: Manufacturer: PNY Tech
[ 280.859405] usb 1-1.1: SerialNumber: 055811050105115493000298
[ 280.864561] usb 1-1.1: usb_probe_device
[ 280.864628] usb 1-1.1: configuration #1 chosen from 1 choice
[ 280.868047] usb 1-1.1: adding 1-1.1:1.0 (config #1, interface 0)
[ 280.868795] usb-storage 1-1.1:1.0: usb_probe_interface
[ 280.868877] usb-storage 1-1.1:1.0: usb_probe_interface - got id
[ 280.872671] scsi0 : usb-storage 1-1.1:1.0
