I am trying to update/upgrade my board w/ this data:
Linux BeagleBone 5.10.168-ti-r72 #1bullseye SMP PREEMPT Sat Sep 30 03:37:21 UTC 2023 armv7l GNU/Linux
BeagleBoard.org Debian Bullseye IoT Image 2023-10-07
P.S. I cannot get wifi to work so far. Oh…I am using Bullseye and just trying to update via wpa_supplicant.
amf99
January 7, 2024, 9:50pm
2
from my notes:
Configure wifi
see:
Network
We migrated from connman to Debian Systemd-Networkd
debian@BeagleBone:~$ sudo networkctl
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 eth0 ether routable configured
3 usb0 gadget no-carrier configuring
4 usb1 gadget no-carrier configuring
5 can0 can off unmanaged
6 can1 can off unmanaged
6 links listed.
Configuration files
eth0 -> /etc/systemd/network/eth0.network
usb0 (Windows - 192.168.7.x) -> /etc/…
2023, connman is out, systemd-netword is in
GL
@amf99 ,
I do not understand. It has auth SSID and Passcode ideas like most but my credentials do not work.
P.S. I am here. I know my SSID and passcode. So, it is bewildering to me why all of a sudden, I am without WiFi capabilities. I did try to set up WiFi a while back on a hidden SSID. No go for whatever reason. Anyway, since then, I prompted the SSID to not be so hidden. It is free to bug…blah.
amf99
January 7, 2024, 10:35pm
4
more notes:
for hidden ssid, add “scan_ssid=1” to network group below (verified, 10/2023)
sudo iw wlan0 scan | grep SSID
network={}, the network group thing above
do you get your SSID when ya run the scan?
remember ya had issues before with a hidden SSID,
Hello again…I am doin’ some other stuff right now but I will get on the wifi kick soon.
Replies on the way!
Also…
ctrl_interface=DIR=/run/wpa_supplicant GROUP=netdev
update_config=1
p2p_disabled=1
#country=US
network={
ssid="Gafter"
psk="1800_##?_BBAI"
Does this look right?
Linux BeagleBone 5.10.168-ti-r72 #1bullseye SMP PREEMPT Sat Sep 30 03:37:21 UTC 2023 armv7l GNU/Linux is the kernel while…
BeagleBoard.org Debian Bullseye IoT Image 2023-10-07 is the image
sudo iw wlan0 scan | grep SSID shows my SSID plain Jane.
P.S. Here is the info. about the failure in installing with apt update.
Err:1 http://security.debian.org/debian-security bullseye-security InRelease
Temporary failure resolving 'security.debian.org'
Err:2 http://repos.rcn-ee.com/debian bullseye InRelease
Temporary failure resolving 'repos.rcn-ee.com'
Err:3 http://deb.debian.org/debian bullseye InRelease
Temporary failure resolving 'deb.debian.org'
Err:4 http://deb.debian.org/debian bullseye-updates InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease Temporary failure resolving 'deb.debian.org'
W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease Temporary failure resolving 'security.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease Temporary failure resolving 'deb.debian.org'
W: Failed to fetch http://repos.rcn-ee.com/debian/dists/bullseye/InRelease Temporary failure resolving 'repos.rcn-ee.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Should I try bookworm?
Hmm…I think it is the location of the beacon:
Inter-| sta-| Quality | Discarded packets | Missed | WE
face | tus | link level noise | nwid crypt frag retry misc | beacon | 22
See…I have noise and that usually equates to lengthy distances in reception. Right? I will try to get closer… Argh!
Distance…DISTANCE! That was it. I am sorry to harass everyone again…
