Hello everyone,
I have flashed my BeagleBone Black Wireless to the latest IoT image, but the image doesn’t contain connman package and other packages too. Is there any solution to enable wifi, at the moment ifconfig doesn’t show wlan0.
Hello everyone,
It should have systemd-networkd
In Debian Bullseye (11.x) we moved from Connman → systemd-networkd + wpa_supplicant
I’ve listed hints using wpa_cli and wpa_supplicant-wlan0.conf here: Debian 11.x (Bullseye) - Monthly Snapshot - 2023-09-02
I tried instructions and my wpa_supplement.conf looks like that:
ap_scan=1
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
#p2p_disabled=1
country=BE
network={
ssid=“M319B98”
psk=“99999999”
But I have following error, when I run wpa_cli -i wlan0 reconfigure:
Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
wlan0 interface is “off” and its setup is “configuring”
Same issue here, please help
Hello @Srujan_Sriram ,
If you are using Bullseye, go to this file to enter in your credentials: /etc/wpa_supplicant/wpa_suppliment-wlan0.conf .
If you are using Bookworm, I think there is another file to test but there are particular commands one can use:
Using Bullseye. And I had updated wpa_supplicant-wlan0.conf with my credentials, but I don’t think that is the problem. To begin with does Beaglebone Black Rev C3 even have Wifi ?
This is my image:
AM335x 11.7 2023-09-02 4GB microSD IoT
](AM335x 11.7 2023-09-02 4GB microSD IoT - BeagleBoard)
No. It only has Ethernet. The BeagleBone Black Wireless, sort of in the name, is the BBB w/ WiFi.
There is also some other boards like the BBGW, BBGG, and BBAI that have WiFi access to ssh among other things.
P.S. The newer boards like the BBAI-64 has M.2 key access for WiFi, the BeagleV-Ahead has WiFi, and the Play has WiFI also. Now, I know nothing about the Play for now but hopefully one day I can get my hands on one to test the speed and connectivity.
I have just flashed my Beaglebone Blue with the latest Bullseye image.
Could someone guide me - in newbie terms - how to do what I would have otherwise done using connmanctl to get on to the local WiFi?
IOW the equivalent of
services to see what’s available
agent on
connect wifi_xxxxx...
Bullesye image use wpa_cli:
You can edit:
sudo nano /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
directly.
Thank you very much. I’ve got the WiFi up and running now.
I’d mention that editing the config file, and then running
sudo wpa_cli -i wlan0 reconfigure
did not get the network recognized, even after shutting down and restarting.
I had to run wpa_cli and do a >scan before it registered, it was fine after that.
PS. I also got VSCode started up on :3000, great!
Is there a location to get all the BeagleBone Blue pinout IDs, etc?
That worked great for Bullseye, many thanks, but now I am trying to set up Bookworm IoT, and there is no /etc/wpa_supplicant directory, nor could I see it anywhere else obviously.
Are the instructions for setting up WiFi on Bookworm different again?
Regards
PS. Thanks, I found iwctl now
off the link above.
Is there an actual documentation page yet, is it all still… samizdat?
