UPDATE: After trying several suggestions, I have ended up in the following situation; I’ve set up an ad-hoc connection (I chose “Shared to other computers” method in the IPv4 setting tab) on my UBUNTU laptop (device A).
https://www.dropbox.com/s/qpb3ggutgos9jfd/scrnshot_19-3_HOSTPC.png?dl=0
Then, I created a connection on my second UBUNTU laptop (device B) with ad-hoc DHCP(auto) and its ESSID was set as the ESSID of the initial connection created on device A.
https://www.dropbox.com/s/wjcijyeehq3080m/scrnshot_19-3_CLIENTPC.png?dl=0
The connection between the two devices worked smoothly.
After that I tried to achieve the same kind of connection, but this time between the device A and a BeagleBoneBlack Wireless (flashed with UBUNTU 16.04 Xenial console). Here’s the edited /etc/network/interfaces file for the wlan0 connection: https://www.dropbox.com/s/yw5ux8k6x1wtqke/interfaces_19-3.png?dl=0
However, this time a connection was not established.
ifconfig for the BBBW: https://www.dropbox.com/s/s3viflkdwufx6yx/scrnshot_19-3_BBBW.png?dl=0
I am also posting the results of the wireless-info script: https://www.dropbox.com/s/9ihnkysc3lhs5tv/wireless-info_19-3_BBBW.txt?dl=0
Any advice?
UPDATE: I ran a diagnostics script for Beagleboards named version.sh. Here are the results: https://www.dropbox.com/s/kimbj5ntao…on_sh.txt?dl=0
In line 10 it shows a warning about a firmware package not having been installed.
Ubuntu doesn't have that specific package, instead they install the
needed firmware thru the "linux-firmware" package, which is installed.
The main problem with ubuntu 16.04, the default version of connman is
too old to be useful. (1.21)
When i back ported a newer version of connman, most users complained
about it, so i removed it.
So for ubuntu 16.04, it's up to "YOU" to configure wifi, thru
wpa-supplicant and friends. I'm not wasting personal time on 16.04.
For ubuntu 18.04, ubuntu has a much newer version of connman that works well.
I know this comes later than expected, but after some experimentation, the following steps solved all of my problems:
I installed the March ubuntu 16.04 image file instead of the February one, since it solved all problems with cape managers.
I tried downloading this file:
sudo wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/ti-connectivity/wl18xx-fw-4.bin
as advised by this forum: https://ubuntuforums.org/showthread.php?t=2386780, and replacing the existing file at:
/lib/firmware/ti-connectivity
To create a wi-fi interface connection between BBBW and your PC do the following at your PC, using ubuntu’s GUI program Network Connections:
To create a wi-fi interface connection between BBBW and your PC do the following at BBBW, using the serial console and the minicom program:
Edit the interfaces file in BBBW using:
sudo nano /etc/network/interfaces
Comment the lines:
auto wlan0 iface wlan0 inet dhcp wpa-ssid hotSpotPC wpa-psk useTheDefaultPassword
