I have a beaglebone black and am using it at a college for research. I tried to connect the black to a monitor but it doesn’t seem to want to hold the signal for more than a minute. When I connect the board to a monitor the desktop will display for a minute or two and then the monitor will shut off and show “Check signal cable” or “no signal”. I had the same problem with 5 other monitors. Is the board damaged? What should I do to get the beaglebone black to work on a monitor?
Also, I used a micro hdmi to VGA adapter to connect to the monitor and I also tried using a micro hdmi to hdmi type-A cable connected to a DVI-D adapter, that also didn’t work.
The micro hdmi to VGA adapter is a recommended component to use to connect a monitor on the circuitco beaglebone black accessories wiki.
Please help with this issue.
Russell Taylor
Research Assistant, Red River College
Winnipeg, Manitoba
