Curious if someone can tell me what I should expect for analog readings from bonescript (nodejs)
If I do an analogread() on pin 38 with my TMP36 temperature sensor plugged in I get a value of .4011234
I’m not sure what that value is supposed to mean. Is it volts? My multi meter reutrns a value of .701 volts.
I plugged the sensor into my arduino just for fun and get readings of like 150 which I can translate to like 72F for the temperatue so I know the sensor is working, I just cant figure out what I should be seeing from my beaglebone to know how to start converting it to a temperature.
Thanks in advance for the help.
