I don’t think the update/write rate on the card could cause such an issue, 227 access / hour doesn’t seem too much. But there’s something very easy you could try if your system runs continuously : write to the RAM instead of the directly to the card using the tmpfs filesystem : https://groups.google.com/forum/?fromgroups=#!topic/beagleboard/TK9PbsnKZro . Then you can then copy what’s you’re interested in to the disk when the program closes.
Hope this helps, good luck with that.
