Hello everyone,
I have been looking around and trying to find answers for my problem but I have yet to run into a solution.
So, I currently have the latest release of Angstrom for Beaglebone and I have the latest g++ for it (4.5.4 I believe but I would prefer to have 4.7.2). The kernel is 3.2.42 I believe.
I have coded the threading example here: http://www.cplusplus.com/reference/thread/thread/ and compiled with combinations of -pthread, -lpthread, -std=c++0x, and std=c++11 but I always get an error “pure virtual method called; terminate called without an active exception; Aborted”.
I have looked around and it seems that can be fixed by g++ v4.7+ so I decided to cross compile on my Ubuntu with g++ v4.7.2. I configured all the necessary things required to cross compile on ARM and deploy on Beaglebone but I either get the error of the one I mentioned or this “terminate called after throwing an instance of ‘std::system_error’; what():; Aborted”.
I have also looked around for that previous error but the suggested solutions for that error did not help me at all.
Has anyone gotten C++ and threading to work with Angstrom? If so, or if you know a solution to my issue, could you point me to the right direction?
Thank you so much.
