BeagleBone camera cape on Ubuntu 14.04
Hi
I have a BeagleBone camera cape from QuickLogic like the one shown here: http://elinux.org/CircuitCo:BeagleBone_3.1MP_Camera.
I am running Ubuntu 14.04 on a BeagleBone Black. It looks like Ubuntu does not support the cape out of the box. I have spent a lot of time looking for a driver but could not find anything useful. I got the Ubuntu 14.04 image from here: http://elinux.org/BeagleBoardUbuntu.
Angstrom on the other hand does come with camera cape support. It is mounted as /dev/video0, just like any V4L2 compatible device.
Can anoyone tell me how do I mount the camera as a V4L2 device on Ubuntu?
To fully support that cape, you need to downgrade to the v3.8.x kernel:
sudo apt-get update
sudo apt-get install linux-image-3.8.13-bone69
sudo reboot
Hi Robert
Thanks a lot for your response. After downgrading the kernel, I got /dev/video0. The problem is, I cannot get an image from the camera. All I get is a black frame. I have tried both OpenCV and v4l2grab (https://github.com/twam/v4l2grab). The result was the same black image. Here are some (possibly) relevant information:
ubuntu@arm:~$ v4l2-ctl --info
Driver Info (not using libv4l2):
     Driver name   : cssp_camera
     Card type     : cssp_camera
     Bus info      : cssp_camera-000
     Driver version: 3.8.13
     Capabilities  : 0x05000001
         Video Capture
         Read/Write
         Streaming
ubuntu@arm:~$ v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
     Index       : 0
     Type        : Video Capture
     Pixel Format: 'YUYV'
     Name        : 4:2:2, packed, YUYV
     Index       : 1
     Pixel Format: 'RGBP'
     Index       : 2
     Pixel Format: 'RGBO'
ubuntu@arm:~$ v4l2-ctl -V
Format Video Capture:
     Width/Height  : 640/480
     Pixel Format  : 'YUYV'
     Field         : None
     Bytes per Line: 1280
     Size Image    : 614400
     Colorspace    : JPEG (JFIF/ITU601)
Here is the relevant portion from dmesg (immediately after trying to capture an image with OpenCV): https://gist.github.com/shahriman/0c7d8dd2683a5d1abb8d.
I will really appreciate it if you can provide me some hint as to what might be the issue here.
Regards
Shakkhar
A common issue with this camera is that it takes several frames for the
automatic gain to kick in. Thus, you get black frames at first. Try
capturing a couple hundred frames at the same time and then look at the
last one.
Indeed, that did the trick. Thank you very much. Regards Shakkhar
