Hi Robert,
Here below is my boot log:
U-Boot 2018.09-00002-gd5b4c4b656 (Oct 19 2018 - 14:16:02 -0500), Build: jenkins-
github_Bootloader-Builder-84
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
Reset Source: Global warm SW reset has occurred.
RTC 32KCLK Source: External.
Loading Environment from EXT4… ** File not found /boot/uboot.env **
** Unable to read “/boot/uboot.env” from mmc0:1 **
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
Timed out in wait_for_event: status=0000
Check if pads/pull-ups of bus are properly configured
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] …
board_rev=[000C] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
2100 bytes read in 20 ms (102.5 KiB/s)
debug: [dtb=am335x-boneblack.dtb] …
Using: dtb=am335x-boneblack.dtb …
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.9.45-ti-r57 …
9464664 bytes read in 612 ms (14.7 MiB/s)
debug: [enable_uboot_overlays=1] …
debug: [enable_uboot_cape_universal=1] …
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] …
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] …
debug: unable to find [am335x-boneblack-uboot-univ.dtb] using [am335x-boneblack-
uboot.dtb] instead …
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot.dtb] …
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] …
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot.dtb …
loading /boot/dtbs/4.9.45-ti-r57/am335x-boneblack-uboot.dtb …
55752 bytes read in 36 ms (1.5 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo …
1440 bytes read in 345 ms (3.9 KiB/s)
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo …
4920 bytes read in 219 ms (21.5 KiB/s)
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo …
711 bytes read in 599 ms (1000 Bytes/s)
uboot_overlays: loading /lib/firmware/univ-bbb-EVA-00A0.dtbo …
61976 bytes read in 644 ms (93.8 KiB/s)
loading /boot/initrd.img-4.9.45-ti-r57 …
6395122 bytes read in 420 ms (14.5 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mm
cblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet video=H
DMI-A-1:1024x768@60e] …
debug: [bootz 0x82000000 0x88080000:6194f2 88000000] …
Loading Ramdisk to 8f9e6000, end 8ffff4f2 … OK
reserving fdt memory region: addr=88000000 size=7d000
Loading Device Tree to 8f966000, end 8f9e5fff … OK
Starting kernel …
[ 0.001790] clocksource_probe: no matching clocksources found
[ 2.416644] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.670204] omap_voltage_late_init: Voltage driver support not added
[ 2.677613] PM: Cannot get wkup_m3_ipc handle
[ 3.167898] musb-hdrc musb-hdrc.1: VBUS_ERROR in a_wait_vrise (80, <SessEnd),
retry #3, port1 0008010c
[ 4.089472] tda998x 0-0070: read edid timeout
[ 4.185191] bone_capemgr bone_capemgr: slot #0: auto loading handled by U-Boo
t
[ 4.192591] bone_capemgr bone_capemgr: slot #1: auto loading handled by U-Boo
t
[ 4.200032] bone_capemgr bone_capemgr: slot #2: auto loading handled by U-Boo
t
[ 4.207386] bone_capemgr bone_capemgr: slot #3: auto loading handled by U-Boo
t
[ 6.389654] tda998x 0-0070: read edid timeout
rootfs: clean, 127622/217728 files, 744131/869376 blocks
Debian GNU/Linux 9 beaglebone ttyS0
BeagleBoard.org Debian Image 2017-08-31
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
beaglebone login: debian
Password:
For the same image, please also see my boot log on beaglebone.
U-Boot 2016.03-00001-gd12d09f (Mar 17 2016 - 16:16:15 -0500), Build: jenkins-gi1
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
cpsw, usb_ether
Scanning mmc 0:1…
2080 bytes read in 40 ms (50.8 KiB/s)
9464664 bytes read in 546 ms (16.5 MiB/s)
loading /boot/dtbs/4.9.45-ti-r57/am335x-boneblack.dtb …
58161 bytes read in 95 ms (597.7 KiB/s)
6395122 bytes read in 384 ms (15.9 MiB/s)
debug: [console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait .
debug: [bootz 0x82000000 0x88080000:6194f2 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x906b58 ]
Loading Device Tree to 8f9d4000, end 8f9e5330 … OK
Starting kernel …
[ 0.000861] clocksource_probe: no matching clocksources found
[ 2.352397] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.570055] omap_voltage_late_init: Voltage driver support not added
[ 2.577597] PM: Cannot get wkup_m3_ipc handle
[ 2.944617] bone_capemgr bone_capemgr: slot #0: No cape found
[ 2.975621] bone_capemgr bone_capemgr: slot #1: No cape found
[ 3.008278] bone_capemgr bone_capemgr: slot #2: No cape found
[ 3.040942] bone_capemgr bone_capemgr: slot #3: No cape found
rootfs: recovering journal
rootfs: Clearing orphaned inode 72631 (uid=0, gid=0, mode=040700, size=4096)
rootfs: Clearing orphaned inode 72632 (uid=0, gid=0, mode=041777, size=4096)
rootfs: clean, 126996/217728 files, 740103/869376 blocks
[ 18.675503] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000020): FIFO underflow
[ 18.683167] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.690576] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.699830] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.700543] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.716500] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.717208] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.733165] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.733870] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.749842] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 18.750537] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost
[ 19.133859] tilcdc 4830e000.lcdc: tilcdc_crtc_irq(0x00000004): Sync lost flog
beaglebone login:
