I’m new to using the Beaglebone. I decided to use it on one of my current projects. When I heard about the Beaglebone Green I decided that would be the one I get since I have no need for HDMI in my application. Anyways the BBG for me is functioning as a way to deploy a java application that communicates with the cloud and custom electrical hardware via USB/WiFi.
So anyways I need Java to run my application as a packaged .JAR executable, so I installed the Linux ARM Java manually, by downloading it on my local machine and transfering it to the /temp folder, I unpacked it into the correct directory and set the PATH variable to make it available for use. I checked the Java version to make sure I installed it correctly. Next off I installed Maven and Gradle, I tested them by checking their version and confirmed they installed successfully. The reason I need all this stuff is because a piece of software called BowlerStudio I’m using in my main application runs off Java 8 and requires Maven and Gradle to build. When I attempt to build the application from source its seems to have an issue locating the JavaFX Libraries that are supposed to be included in the latest version of Java for ARM, the latest version and the version I intalled was Java 8 update 60 for ARM. Any idea why its unable to find JavaFX ?
BowlerStudio
https://github.com/NeuronRobotics/BowlerStudio
What steps did you use to install Java? I think there are multiple builds/packages for Java 8 update 60 for ARM.
I've been slacking on java..
Oracle Java 8 update 33 was the version i had packaged for
"oracle-java8-installer"
Right now i'm building the install for Oracle Java 8 update 60..
I've noticed Oracle Java 9 Beta 81 is now out, does anyone want that packaged?
Robert, do you still follow the Oracle java updates?
They have not been updated in a while.
I am using these to run OpenHab on a Beaglebone, as the openjdk version seems to be a lot slower.
Anyone else experiences with speed differences between openjdk and oracle jdk?
Kind Regards,
Johan
Not really.. only if people ask..
jdk?
Well i updated Java 8 for you:
https://github.com/rcn-ee/repos/commit/20dac792c418534741f5a515eba68674bfa37a35
Just "sudo apt update ; sudo apt upgrade" to get it..
Otherwise it looks like Java 9 is now a no go for ARM:
http://www.oracle.com/technetwork/java/javase/downloads/jdk9-downloads-3848520.html
Thanks!
The missing java 9 distribution is odd, I am sure I saw a version 9 arm version a few days ago.
Kind Regards,
Johan
jdk?
Do you have any details on versions , workloads , throughput/ latency
numbers etc? The oracle and OpenJdk codebases are different (different JIT
compilers etc) for ARM so you will likely see differene performance results.
Would be interesting to see.
Alex
