BeagleBone Green does not work after kernel update
Hi everyone
I have a BeagleBone Green on my hand and ran with a old kernel from 2017.
I notice the device has some issues and they may lie in the kernel, so I did a kernel update as instructed here.
After the update, I tried to reboot it but it never came up again, so I unplugged the power and powered on again.
The BeagleBone started, but I couldn’t SSH to the device. And the USB is enumerated as USB COM PORT on my PC (WIN10 64bits)
I tried many things to bring it back but it didn’t work.
What should I do now? Should I re-flash the whole image with SD card?
Thanks a lot in advance!
Do you have an FTDI cable you can connect to the BBG?
https://wiki.seeedstudio.com/BeagleBone_Green/
Also, on your Win10 system, are you getting the Remote NDIS Ethernet interface show for the BBG ?
If you are. check the IP address assigned to this. If you had a shared connection on your Win10 system for the BBG, disable the shared connect and try resetting the USB connection again.
If not, perhaps a driver is missing.
Cheers,
Jon
Use the serial console instead of ssh. Then, use this command: ip addr. Find what the ip address to your machine is currently. Then, use that to sign in.
Hello everyone, I need a hand from all of you, if you have a driver for BBG, please reply my email
Pada Minggu, 17 Januari 2021 pukul 13.27.22 UTC+7 set_ menulis:
