What are your preprocessor directives? And…why do you not want to use GPIO in C instead? If you wanted to use C or Python3, easier methods are available. I searched online just now. I came across many libs but one that may prove useful in your C++ case:
Example of using libsoc for GPIO programming.
Toggles three LEDs in a "Cylon" pattern until the pushbutton is
pressed, and then exits. Will run on Raspberry Pi or Toradex Colibri
platforms.
This version reads the switch status using interrupts and a callback.
#include <stdio.h>
#include <unistd.h>
#include "libsoc_gpio.h"
#include "libsoc_debug.h"
// Uncomment the appropriate lines below for the hardware it is
// running on.
// Raspberry Pi
//const int led1 = 24; // Red LED
//const int led2 = 25; // Green LED
//const int led3 = 5; // Yellow LED
//const int button = 6; // Pushbutton
// Toradex Colibri
const int led1 = 52; // Red LED
const int led2 = 53; // Green LED
const int led3 = 63; // Yellow LED
const int button = 93; // Pushbutton
// Delay (in microseconds)
const int delay = 100000;
// Exit flag
bool exitLoop = false;
// Callback invoked when button is pressed. Set flag to exit.
int buttonCallback(void* arg)
printf("Button pressed\n");
exitLoop = true;
return 0;
// Main program
int main(void)
// Uncomment the next line to enable debug output if desired.
//libsoc_set_debug(1);
// Request gpios. May need to use LS_SHARED with older versions
// of libsoc.
gpio *gpio_led1 = libsoc_gpio_request(led1, LS_GPIO_SHARED);
gpio *gpio_led2 = libsoc_gpio_request(led2, LS_GPIO_SHARED);
gpio *gpio_led3 = libsoc_gpio_request(led3, LS_GPIO_SHARED);
gpio *gpio_button = libsoc_gpio_request(button, LS_GPIO_SHARED);
// Ensure gpios were successfully requested.
if (gpio_led1 == NULL) {
printf("Failed gpio_led1 request.\n");
exit(EXIT_FAILURE);
if (gpio_led2 == NULL) {
printf("Failed gpio_led2 request.\n");
exit(EXIT_FAILURE);
if (gpio_led3 == NULL) {
printf("Failed gpio_led3 request.\n");
exit(EXIT_FAILURE);
if (gpio_button == NULL) {
printf("Failed gpio_button request.\n");
exit(EXIT_FAILURE);
// Set directions.
libsoc_gpio_set_direction(gpio_led1, OUTPUT);
libsoc_gpio_set_direction(gpio_led2, OUTPUT);
libsoc_gpio_set_direction(gpio_led3, OUTPUT);
libsoc_gpio_set_direction(gpio_button, INPUT);
// Check directions.
if (libsoc_gpio_get_direction(gpio_led1) != OUTPUT) {
printf("Failed to set direction of gpio_led1\n");
exit(EXIT_FAILURE);
if (libsoc_gpio_get_direction(gpio_led2) != OUTPUT) {
printf("Failed to set direction of gpio_led2\n");
exit(EXIT_FAILURE);
if (libsoc_gpio_get_direction(gpio_led3) != OUTPUT) {
printf("Failed to set direction of gpio_led3\n");
exit(EXIT_FAILURE);
if (libsoc_gpio_get_direction(gpio_button) != INPUT) {
printf("Failed to set direction of gpio_button\n");
exit(EXIT_FAILURE);
// Set input edge to FALLING.
libsoc_gpio_set_edge(gpio_button, FALLING);
// Set up callback when button status changes.
libsoc_gpio_callback_interrupt(gpio_button, &buttonCallback, (void *) 0);
while (!exitLoop) {
// Turn LEDs on and off in desired sequence.
libsoc_gpio_set_level(gpio_led1, HIGH);
libsoc_gpio_set_level(gpio_led2, LOW);
libsoc_gpio_set_level(gpio_led3, LOW);
usleep(delay);
libsoc_gpio_set_level(gpio_led1, LOW);
libsoc_gpio_set_level(gpio_led2, HIGH);
usleep(delay);
libsoc_gpio_set_level(gpio_led3, HIGH);
usleep(delay);
usleep(delay);
// Cancel the callback as it is no longer needed.
libsoc_gpio_callback_interrupt_cancel(gpio_button);
// Turn all LEDs off.
// Clean up.
libsoc_gpio_free(gpio_led1);
libsoc_gpio_free(gpio_led2);
libsoc_gpio_free(gpio_led3);
libsoc_gpio_free(gpio_button);
return EXIT_SUCCESS;
I am not sure about the two libraries above but I think you can port this source to the BBB if needed:
I have not used this source before today. I may not use it but it is a starting point. I do not use libsoc_gpio.h in any form so far.
P.S. It might get you on track! The source and other ideas for GPIO can be found here: blogs/demo2.cpp at master · tranter/blogs · GitHub
