BeagleBone Green New Debian 12.2 Bookworm image - Unable to SSH, No IP address
I’ve flashed an SD card with a fresh 12.2 Bookworm IoT image from the website. Once I flash it and plug it into the BeagleBone, I have no SSH access and cannot ping 192.168.7.2 as expected. I’ve tried reflashing twice with no success.
Upon boot, I get this output through FTDI serial:
U-Boot 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
RTC 32KCLK Source: External.
Core:  150 devices, 14 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing (60s timeout)
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: SeeedStudio BeagleBone Green:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   Could not get PHY for ethernet@4a100000: addr 0
eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[BBG1] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Couldn't find partition 0:2 0x82000000
Can't set block device
Scanning mmc 0:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 3 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
1713 bytes read in 4 ms (418 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.168-ti-r72 ...
11325952 bytes read in 718 ms (15 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/5.10.168-ti-r72/am335x-boneblack-uboot-univ.dtb ...
210757 bytes read in 19 ms (10.6 MiB/s)
Found 0 extension board(s).
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r72/overlays/M-BB-BBG-00A0.dtbo ...
418 bytes read in 6 ms (67.4 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r72/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 7 ms (89.8 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r72/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 6 ms (260.7 KiB/s)
loading /boot/initrd.img-5.10.168-ti-r72 ...
7844660 bytes read in 502 ms (14.9 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:77b334 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xacd200 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f884000, end 8ffff334 ... OK
   Loading Device Tree to 8f7ed000, end 8f883fff ... OK
Starting kernel ...
[    0.151303] l3-aon-clkctrl:0000:0: failed to disable
[   10.061189] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[   10.093680] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[   10.093707] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[   10.524031] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
[   10.739842] omap_voltage_late_init: Voltage driver support not added
[   10.887210] mdio_bus 4a101000.mdio: MDIO device at address 0 is missing.
trap: EXIT: bad trap
[   28.634522] cpsw 4a100000.ethernet: phy "/ocp/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000/ethernet-phy@0" not found on slave 0
Debian GNU/Linux 12 BeagleBone ttyS0
BeagleBoard.org Debian Bookworm IoT Image 2023-10-07
Support: https://bbb.io/debian
default username:password is [debian:temppwd]
Web console: https://BeagleBone.localdomain:9090/
BeagleBone login:
I find the trap: EXIT: bad trap a bit suspicious, but I don’t know what it could mean. I can login through the serial terminal.
ifconfig shows:
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b0:d5:cc:fd:b6:4d  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 18  bytes 3113 (3.0 KiB)
        TX packets 18  bytes 3113 (3.0 KiB)
usb0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b0:d5:cc:fd:b6:50  txqueuelen 1000  (Ethernet)
192.168.7.2 is not shown as I would expect.
networkctl:
IDX LINK TYPE     OPERATIONAL SETUP
  1 lo   loopback carrier     unmanaged
  2 eth0 ether    no-carrier  configuring
  3 usb0 gadget   no-carrier  configuring
  4 can0 can      off         unmanaged
  5 can1 can      off         unmanaged
Is this behavior expected for 12.2 image? If so, I would I configure the OS to expose the 192.172.7.2 through the USB connection?
Thank you
kernel 5.10.x got a new network driver, so the old mdio bus workaround we had used since 3.8.x no longer works.
Either down-grade to the v4.19.x based kernel or remove C24, which should fix the phy problem on your board.
Oh usb0 should be active, try running sudo dhclient on the interface shown up on your host machine…
Trying to understand. Is this related to connecting to BB over USB at 192.168.7.2?
Can you help me locate C24 on the BBG? I’m not able to view SeeedStudio’s PCB file to find where it is, and the schematic gives me an idea of where it might be but not total confidence. There’s little info on the silkscreen.
Sorry, I might need a little bit of handholding here. I wasn’t sure what you meant, but did try running these commands on the BB side through PuTTY over serial (I’m on Windows):
sudo dhclient usb0
sudo dhclient eth0
sudo dhclient
But I see no changes when I try ifconfig again.
Some additional info…
I also have an SD card with Debian 11.7 flashed and with kernel 5.10.x, but I am able to connect over USB just fine. Here’s the U-Boot output when I insert the 11.7 SD card:
DRAM:  512 MiB
BeagleBone Black:
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Scanning mmc 0:1...
Found 3 disks
2448 bytes read in 4 ms (597.7 KiB/s)
loading /boot/vmlinuz-5.10.168-ti-r71 ...
11342336 bytes read in 719 ms (15 MiB/s)
loading /boot/dtbs/5.10.168-ti-r71/am335x-boneblack-uboot-univ.dtb ...
210757 bytes read in 20 ms (10 MiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/M-BB-BBG-00A0.dtbo ...
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-ADC-00A0.dtbo ...
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-UART1-00A0.dtbo ...
1017 bytes read in 7 ms (141.6 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-SPIDEV0-00A0.dtbo ...
1522 bytes read in 7 ms (211.9 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 7 ms (223.6 KiB/s)
loading /boot/initrd.img-5.10.168-ti-r71 ...
7719588 bytes read in 494 ms (14.9 MiB/s)
debug: [bootz 0x82000000 0x88080000:75caa4 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xad1200 ]
   Loading Ramdisk to 8f8a3000, end 8ffffaa4 ... OK
   Loading Device Tree to 8f80c000, end 8f8a2fff ... OK
Starting kernel ...
[    0.152234] l3-aon-clkctrl:0000:0: failed to disable
[    9.357475] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    9.389965] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[    9.389996] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[    9.799467] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
[    9.995071] omap_voltage_late_init: Voltage driver support not added
Debian GNU/Linux 11 BeagleBone ttyS0
On a somewhat related note, I tried the 12.2 SD card on a newer BeagleBone Green (v1.2) vs the original older one, v1.0, and the U-boot version string is:
U-Boot 2018.01-00002-gbbdeb63-dirty (May 08 2018 - 15:14:23 +0800)
The eMMC is also wiped on this BB. I’m curious: where U-Boot lives on the physical system if not on the SD card or eMMC?
Which version of windows?
Windows 10.0
Yeap, RNDIS drivers..
From usb serial in windows… Open /etc/default/bb-boot and disable:
USB_RNDIS_DISABLED=yes → #USB_RNDIS_DISABLED=yes
then reboot..
been hacking on other things, i will probally revert that default so RNDIS/NCM is enabled for another year..
That worked, thanks! I didn’t not catch that note about RNDIS, thanks for pointing me to it.
I’d still like to know how this works if you could please answer:
Okay I pushed the rndis enable flag as part of our (in-development) generic sysconf.txt initial setup script… bbbio-set-sysconf: enable switch for legacy_rndis_support=enable (4d31a0c1) · Commits · BeagleBoard.org / bbbio-set-sysconf · GitLab
On am335x devices, U-boot lives in the MBR of either (or both) the SD or (and) eMMC… if you run fdisk on a the drive you’ll find a 4MB hole, it’s in there.
