I am using beaglebone greeen wireless board.
I used image: am335x-eMMC-flasher-debian-11.7-iot-armhf-2023-09-02-4gb.img.xz
I am not able to connect to WPA3 wifi network.
I wanted to know if there is WPA3 support present on beaglebone green wireless.
Following are the logs:
> add_network
1
> set_network 1 ssid "pp_wpa3"
OK
> set_network 1 key_mgmt SAE
OK
> set_network 1 sae_password "pp123$pp123"
OK
> set_network 1 ieee80211w 2
OK
> save_config
OK
> enable 1
OK
<3>CTRL-EVENT-SCAN-STARTED
<3>CTRL-EVENT-SCAN-RESULTS
<3>WPS-AP-AVAILABLE
<3>SME: Trying to authenticate with 04:42:1a:60:d6:38 (SSID='pp_wpa3' freq=2442 MHz)
<3>PMKSA-CACHE-ADDED 04:42:1a:60:d6:38 1
<3>Trying to associate with 04:42:1a:60:d6:38 (SSID='pp_wpa3' freq=2442 MHz)
<3>Associated with 04:42:1a:60:d6:38
<3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
<3>WPA: Key negotiation completed with 04:42:1a:60:d6:38 [PTK=CCMP GTK=CCMP]
<3>CTRL-EVENT-CONNECTED - Connection to 04:42:1a:60:d6:38 completed [id=1 id_str=]
<4>WPA: Failed to configure IGTK to the driver
<3>RSN: Failed to configure IGTK
<3>CTRL-EVENT-DISCONNECTED bssid=04:42:1a:60:d6:38 reason=1 locally_generated=1
<3>CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
<3>CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
<3>WPS-AP-AVAILABLE
<3>WPS-AP-AVAILABLE
<3>WPS-AP-AVAILABLE
<3>WPS-AP-AVAILABLE
