Thanks for your responses. See below.
Rick
See below.
> Thanks for the reply.
> Is the MMC interface used by the SD socket on the BB?
It uses one of them.
So is there an MMC interface on the cape connectors that is not used
by the internal circuitry on the BB? Sharing an interface is a lot
harder than using a dedicated interface.
> I assume using
> the GPMC would not interfere with anything else (not sure what GPMC
> is, but I expect the GP is "general purpose", no?)
GPMC..General Purpose Memory Controller..Address, data, control signals.
I assume the DDR memory has it's own interface separate from the
GPMC? Or is it easily shared? A 200 MHz interface can create a lot
of issues if there is are multiple drivers, especially going off
board.
> Is the GPMC used
> by any other capes currently?
It does not matter. Cape alignment is something that can't be controlled.
Too big of a task. Besides, each pin can have up to 7 functions on it, so
these pins can be all sorts of signals. You can look at the System
Reference Manual for more information.
It may not matter to you, but I see no reason to walk into a wall if
I can see it in my way. I may decide to continue use the interface
anyway, but I would like to know if any of the current capes use this
interface. If you don't know, that's fine.
Is there any sort of guide to the expansion bus usage by the various
capes?
> I assume if I dig in the user guide for
> the CPU chip I will find timing info on the interface?
Yes. Look at the SRM first to see th epins on the expansion headers.
> Hopefully
> matched lengths won't be required. I expect it can be slowed down if
> needed.
It can be, but if you do a PCB, matched lengths is not that big of a deal.
Only if I am not aiming at a moving target. I don't have control over
the BB layout unless I decide to manufacture the BB as well. So for
now I would prefer to avoid dealing with matching lengths if that is
not a design spec on the BB. Or are you saying that the BB has
matched lengths for this interface going to the connector?
> How is the GPMC supported in software?
Should be, It maps as memory to the processor, just read and write to the
address. You have to set up the pin muxing.
Ok, memory mapped I/O is great. I can implement a virtual FIFO on my
side.
> I think 200 MB/s is plenty of
> speed for anything I would want to do assuming it could actually be
> supported in the software. I expect continuous operation at 200 MB/s
> would not be possible, but any idea of what is a practical max to/from
> memory?
Well, you have DMA that can be used to read it into DDR. Of course if that
is faster than the SW can operate on it, it may not be needed.
High burst speeds are never a problem and can reduce latencies. If
there a bottlenecks elsewhere that is not the concern here. Best that
the bottleneck is not the interface.
