This successfully built:
u-boot-beaglebone-2013.04-r0.img
at this location:
.../deploy/images/beaglebone
I seem to be able to build just the kernel using this:
bitbake -c clean virtual/kernel
bitbake -c compile virtual/kernel
bitbake -c deploy virtual/kernel
These are some of the recipes that I have tried for u-boot, but they don't
seem to rebuild the u-boot image:
bitbake virtual/bootloader
bitbake u-boot
It seems like maybe the u-boot is something like:
bitbake u-boot-denx
However, I was never able to get the u-boot.img to show up at:
setup-scripts/build/tmp-angstrom_v2012_12-eglibc/deploy/images/beaglebone
I commented out “rm_work” in setup-scripts/conf/local.conf and was able to find the u-boot.img after the bitbake at:
setup-scripts/build/tmp-angstrom_v2012_12-eglibc/work/beaglebone-angstrom-linux-gnueabi/u-boot-denx-2013.04-r0/image/boot
CROSS_COMPILE=arm-angstrom-linux-gnueabi- make am335x_evm
Please note, I only saw the binaries come out, I HAVE NOT tested them, but the compile process on angstrom completed after about 10-15 minutes and I seemed to have all the various binaries it producted. I will playing around with this a bit myself today, so if I come up with something I will post my results back here. BTW, thanks for your help on the serial access to my other threads Re: u-boot and getting serial access.
The u-boot that is built by “bitbake systemd-image” includes these patches:
0001-beaglebone-default-to-beaglebone-black-for-unknown-E.patch
0002-am335x-mux-don-t-hang-on-unknown-EEPROMs-assume-Beag.patch
0003-beaglebone-HACK-always-return-1-for-is_bone_lt.patch
0004-beaglebone-HACK-raise-USB-current-limit.patch
0005-beaglebone-use-kloadaddr-to-avoid-copying-the-kernel.patch
0006-beaglebone-try-to-load-uEnv-uImage-from-eMMC-first.patch
0007-beaglebone-Don-t-trigger-uboot-variable-lenght-limit.patch
0008-beaglebone-HACK-change-mmc-order-to-avoid-u-boot-cra.patch
0009-beaglebone-update-bootpart-variable-after-mmc-scan.patch
0010-am335x_evm-enable-gpio-command.patch
0011-am335x_evm-HACK-to-turn-on-BeagleBone-LEDs.patch
0012-Fix-for-screen-rolling-when-video-played-back-in-bro.patch
0013-beaglebone-enable-CONFIG_SUPPORT_RAW_INITRD-option.patch
0014-mmc-Add-RSTN-enable-for-emmc.patch
0015-workaround-EEPROMs-filled-with-zeroes.patch
I am unclear about how many of these patches are specific to the BeagleBone Black.
You can use his instructions to successfully build u-boot (make sure to include his patch):
You place MLO, u-boot.img, and uEnv.txt in the first “FAT” partition.
If you use this for the contents of uEnv.txt, it will boot Angstrom in the second Unix partition:
loadfdt=load mmc ${mmcdev}:2 ${fdtaddr} /boot/${fdtfile}
loaduimage=load mmc ${mmcdev}:2 ${loadaddr} /boot/uImage
uenvcmd=run loaduimage; run loadfdt; run mmcargs; bootm ${loadaddr} - ${fdtaddr}
